Results 1 to 15 of 15
05-01-2009 #1Registered User
- Jun 2006
- Halden, Norway, Europe
- 213
Problem with SPC front LCA + AFX + tie rods + stock sway bar. 64 A-body/Chevelle
Hi,
after waiting for ages for the correct idler arm I've finally about to finish my front end rebuild.
1. Can't mount sway bar! The tie rods ends are mounted too far forward/too high compared to the stock location. Perhaps because the SPC lowers moves the ball joint forward and the AFX spindle moves the tie rod mount location up to avoid bumpsteer.
- Buy new swaybar with different layout? OR
- Buy new and longer sway bar mount bolt?
2. Visible toe-out even when tie rod sleeve is adjusted to it's innermost position. Tie rods are exactly as long as the old ones. The new adjustment sleeve is about 1/2" shorter than the old one. New center link is also exactly like the old one. I don't know if the AFX spindle steering arms moves the tie rod end mount point in towards the frame.
- Use the old/stock tie rod sleeve (bad solution though)? OR
- Cut the tie rod ends?
Parts list:
- SPC UCA + LCA for AFX spindle
- AFX spindle w/A-body steering arms
- Supposedly matched front end steering linkage kit (Moog). Turned out to be the wrong idler arm.
- Tie rod adjuster sleeves (Spohn) included in above mentioned kit.
