    Results 1 to 10 of 10
      Dec 2008
      british columbia
      12 inch brakes ona g-body
      I want too keep the drop spindles iff possible, but would like to know what are my options and not braking the bank for 12 inch brakes for my g-body. thanks... thats on the front nad the rear ill need an alternative for my 9 inch. thanks
      Cincinnati Ohio
      well g body and S-10 stuff swap out, so i have been told.
      I have done 12" and 13" rotor kits for S-10's 2" drop spindles.
      Dec 2008
      british columbia
      yes the spindles swap out, any more info on those kits? thanks
      Fort Mill, SC
      There's a number of ways to go on both stock and dropped spindles, the bracketry is the same: 12" LS1, and I'm sure a 12" C4 setup could also work on the fronts. As mentioned you could swap the spindles out for stock '98-up Blazer/Envoy spindles which use a dual piston 12" setup stock which is very close to a LS1 design.
      As for the rears, what axle flanges are on the 9" rear?
      Ed
      1970 Camaro RS
      1988 Camaro Iroc-Z
      1991 Camaro RS
      2001 CBR 929RR
      www.flynbye.com
      Dec 2008
      british columbia
      its got big bearing new style...do the new blazer/envoy setup come with drop spindles like the older ones have it? are all the mounting holes and stuff for the bracketry the same? belltech? im asuming thats the only company that sells em...and they are same as gbodies? run the blzer caliper and rotor? thanks
      Dec 2008
      british columbia
      for those who rae doing the ls1 brake swap is it simple as it seems? all you need is machined hub, and brackets you can buy? what did those of you who have done the swap used for hubs? thanks
      Lafayette
      i just did this swap using all of bad94s brackets...check my thread for the pics.....
      Scott
      Built LTX, TKO600, 12Bolt
      Dec 2008
      british columbia
      what year is better for the calipers too look for?
      Lafayette
      i would stick with 98+ f-body or c5 and newer vette...
      Scott
      Dec 2008
      british columbia
      it apears im going the ls route for the fronts with a 13 inch rotor, now what is there fora 9 inch rear of that? 12 or 13 inch units
