Results 1 to 13 of 13
    Oct 2008
    Default Speed Inc ALT. RELOCATION KIT
    We have had these available for some time now, but recently where able to greatly reduce costs.
    The bracket it is a CNC'd billet piece which is polished and includes quality stainless hardware. This kit really makes for a very simple install. The bracket also acts as a the tensioner which helps clean things up.
    NOTE:
    -The stock LS alternator will not work with this kit.
    -The belt is not included in this kit.
    The alternator we designed the kit around is 110 amps.
    We have used this kit on many conversion cars as well as 4th Gen F-bodys with great results over other known brackets with belt issues.
    Reg price is $349.99 shipped
    Sale price is $329.99 shipped
    We have these on the shelf and ready for immediate shipping.
    please email Tom or I
    or
    call the shop for any further info 866-571-7733
    FEW PICS :
    St. Pete FL
    Default
    What size belt would you use?
    HELP!!!
    http://www.pro-touring.com/threads/1...55#post1106255
    1970 Pontiac Pro-Touring Trans Am LS1 550hp Build thread:
    http://www.pro-touring.com/showthread.php?50475
    Oct 2008
    Default
    Quote Originally Posted by cdoggy81
    it would need to be measured since it depends on the following..
    PS pulley
    crank pulley
    no PS
    etc
    Liberal, KS
    Default
    looks good. I'm assuming that you just pull the alt tight against the belt and that elongated hole is to allow this?
    Trey
    ~ Jon Hammond
    build thread http://www.pro-touring.com/showthrea...ghlight=begins
    Oct 2008
    Default
    The bracket is designed so that it acts as a manual tensioner.
    Oct 2008
    Default
    These are on the shelf and can be shipped same day if needed.
    Auburn, CA
    Default
    Does this include the alt also? If not what application does the alt come from?
    Tim Tracy
    Oct 2008
    Default
    The kit includes the alternator and pigtail along with the bracket and hardware. We will still honor the $329.99 shipped if order by the end of Dec.
    thanks for looking
    Auburn, CA
    Default
    Thanks Larry. Is this a readily available alt should it fail in the future?
    Tim Tracy
    St. Pete FL
    Default
    Also, what is the output of it as well?
    HELP!!!
    Oct 2008
    Default
    yes.. it is a readily available
    The output is 105, but we are also working on a higher amp unit, but not sure on the ETA.
    St. Pete FL
    Default
    105 should be enough for a stock system + 1 mid/high amp & 1 sub amp for 2 10's. I'm going to put a big cap on the sub amp too so that would help as well. What do you think???
    HELP!!!
    Oct 2008
    Default
    yes..I think you will be fine. We run these on cars with stand alone ECU's, dual fuel pumps, aftermarket coils etc with no issues.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
