    Jul 2008
    Paradise, Pa
    Default DSE Mini Tub Question!?
    I'm ready to call and order my mini tubs from DSE, but I was wondering if I need to wait until I receive them until I start notching my frame rails and floor. The stock tubs are cut out, and by reading some threads, the dimensions have been given to start cutting. Do I need to wait on the mini tubs and DVD, and are they really that helpful because I hear a lot of guys saying the dimensions for cutting are not that clear.
    THANKS!
    Jackson Ms
    Default
    if the tubs are removed i would copy the pattern of the opening and trace it in the new position.
    i would wait on the parts
    Chris V
    SOLD
    Default
    i would just wait if i were you. you'll save maybe a few days in time... worth it to just have the parts there to make sure everything is dead on, since all our cars are at least slightly different because of their age.
    NY
    Default
    I'd wait on the parts too.
    The needs of the many outweigh the needs of the few.
    Huntington Beach, CA
    Default
    I would wait.
    Measure twice and cut once.
    Rick
    " Better to Be Lucky than Good "
    Jul 2008
    Paradise, Pa
    Default
    Alright I will wait on the parts. Thanks a lot guys!
    Jul 2007
    Los Angeles, CA
    Default
    I don't think it matters. As long as you have the templates from the DVD you can start cutting out the inner fenders and then paste the templates up to the frame, while you are waiting for the parts to arrive.
    You have to have big enough opening to fit the new mini-tubs in anyways before can really fit everything.
    Take a look at the Novice's Mini-tub guide:
    http://www.pro-touring.com/forum/showthread.php?t=46900
    You could get to step #10 or even #11 w/o the tubs. I wouldn't cut the frame rails w/o the templates from the CD thou. But you could certainly even just cut out the old inner fender before the parts arrive even without the templates.
    Hope this helps!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
