      Nov 2003
      St. Louis area
      DSE Deeptub to outer wheel housing alignment
      The alignment holes on my DSE Deep tub and US made outer wheelhousing won't line up. The outer housing matches the repro quarter perfectly where it's clamped into place. If I slide the inner housing back to line up the holes, everything gets thrown off a little. Has anyone else had the same issue? Is it super critical that the alignment holes match up?
      Nathan
      1969 Camaro - 355 sbc, TKO 600, 12 bolt, Global West suspension
      nate, as long as you double/triple check all other fitment i would not lose any sleep over the alignment holes, weld her up. better off to have good fitment, then to have poor fitment but the holes line up
      jake
      Jul 2007
      Los Angeles, CA
      2nd the above.
      On one side of mine I wasn't able to get the alignment holes to match up perfectly w/o throwing the alignment off elsewhere. I would just use the alignment holes to fine tune if possible.
      boerne texas
      3rd that.
      rick k
