      Oct 2007
      orange county, california
      LT1 T56 fluid question
      Alright so i just ripped off the factory shifter to put in a B&M Ripper shifter. I noticed that the giant rectangle that the shifter sits in is empt with about a teaspoons worth of red fluid ( automatic tranny fluid i think) in the bottom of it.
      Is there supposed to be some kind of fluid in their? is is supposed to be dry? what am i supposed to do, do i put in fluid, if so what kind and how much?!?!?!
      thanks guys!
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Aug 2006
      Houston, TX
      No, your fine - the fluid drains out of that area so you won't see much there.
      Oct 2007
      thanks man, i saw that little bit and was so confused, my first time working on a manual as im sure u noticed hahaha
      thanks again!
      Dunwoody, GA
      You put nearly 4 quarts of Dexron 3 in a T56. There is a fill hole on the side. Open that hole and pour from the shifter hole if you have to. Once it starts pouring out the side, you've filled it up. Some people prefer GM Synchromesh for their fluid.
      Trey
      ~ Jon Hammond
      Leominster, MA
      I use Royal Purple Syncromax.
