Results 1 to 1 of 1
    Dublin, CA
    Default 4L60E to Manual Conversion
    The body is just about out of the shop and I keep looking at my subframe sitting in the garage thinking that I should have gone the manual route. Does the 4L60E use a different harness plug then the 5 or 6 speed? Does it just use the speed sensor?
    I am trying to figure out what I would need to modify from my current LT1/4L60E configuration to see if it is worthwhile at this point to do. Thanks.
    1971 Camaro, LT1, 4L60E
Posting Permissions
  • You may not post replies
  • You may not edit your posts
