Results 1 to 10 of 10
07-29-2007 #1Registered User
- Jan 2007
- Royal Oak
- 18
Trick to getting GM HEI Distributor into 68 Camaro?
Is there a trick to getting GM HEI Distributor into 68 Camaro? When I try to install the distributor hits the firewall.
Thanks for any help.
07-29-2007 #2Yep - that's a problem with all 1st gens, the HEI won't fit a stock firewall.
Some guys beat the firewall back with a hammer, but I wouldn't.
Spend the money for an MSD small cap dist and be done with it1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
07-30-2007 #3Registered User- Join Date
- Aug 2004
- 830
before the car was in paint I clearanced the fire wall.
07-31-2007 #4Registered User- Join Date
- Feb 2007
- 164
You could use mounts that move the engine 3/4" forward or just junk the HEI and get an MSD pro billet and coil.
08-02-2007 #5Check your frame position. With the frame in the correct position there IS room for a large HEI distributor while using a stock cross member. Look in the forward body mount brackets (near the firewall) and you will see a small .610" (a little smaller than 5/8") hole. If you put a dowel or alignment pin in this hole it should align with a corresponding hole in the body and the pin should point straight up and down. Sometimes the frames are removed from these cars and not put back in the stock position or they get bumped and move over time. I had an HEI in my freshly restored 69 Z/28 RS. It was a close fit but it did fit.
08-02-2007 #6
