Results 1 to 18 of 18
    Waverly, Kansas
    Default Removing water spots from aluminum
    Got some water spots on my polished aluminum valve covers when my lower radiator hose decided to let go. Now I can't seem to remove the spots / stains from the valve covers. I have tried aluminum polish and even tried a small power ball and not much luck. Anyone have any ideas? Am I going to have to pull them and polish the hell out of them to get the spots removed? Thanks
    Windham, NH
    Default
    Have you tried this yet...?
    I am a big fan of Nevr-Dull. I have used it for years on aluminum parts. It is cheap, but does require a bit of "elbow grease." If you work it good, it will give you a mirror shine.
    Phil
    Build site: www.73camarobuild.com
    Business: www.classiccarblasting.com
    Like us on Facebook!
    Nov 2000
    nolando eastern shoreVA
    Default
    Simichrome or similar pastes
    Steve68- 1968 Camaro SS LS1 T56, 12bolt 3:90's, C5/LS1 brakes IROC box, 18" Fikse Profil 13s, Deep Fathom Green,Spearcos,
    http://www.ls1tech.com/forums/showthread.php?t=475228 some pics
    Lees Summit, Missouri
    Default
    Quote Originally Posted by 69TAPoser
    Phil
    I 2nd this one, great stuff, relatively low elbow grease factor!
    Later - Craig
    finleybrosmotorsports@gmail.com
    '70 Chevelle (in storage now, probably will never be back on its wheels again!)
    Beaufort , NC
    Default
    I never got good results with anything but Mothers aluminum polish for getting water spots off.
    1965 Mustang coupe 347 5 spd cheap touring....
    1992 Lexus SC400 daily SOLD
    1966 Porsche 912 Outlaw SOLD
    1968 Ford F-100 sb SOLD
    Waverly, Kansas
    Default
    Thanks guys - I'll try these out.
    Feb 2002
    Springfield, MO
    Default
    The best luck I had was to spray etching wheel cleaner on them and start over! Mine still have water spots on them since I don't want to go thru that again! Good luck!
    Jimmy
    69 Camaro Twin Turbo'd
    58 Nomad 348 Baby Rat
    California
    Default
    00 or 000 steel wool try a small area first, works on aluminum rims, really depends on the quality of aluminum.
    Harriman, Tennessee
    Default
    Vinegar... but clean it off quickly. Water spots are usually calcium deposits, and the acidity of vinegar will remove them.
    Shiny Side Up!
    Bill
    '72 442 "Inamorata"
    '89 ASC/McLaren
    www.FQuick.com/ProTouring442
    Bill Kistner
    Check out my blog and the latest installment of my current project "In the Company of Devils" at: www.WilliamKElliott.com.
    Oct 2006
    Kansas City
    Default
    Mother's Billet aluminum polish... its not cheap, but it works real well.
    Luke
    '83 Hurst/Olds
    SC&C Stage 2, Blazer spindles/C6 brakes, Lee box, Eibachs, Currectrac rear arms... Olds 433 coming soon.
    Central California
    Default Glass . . .
    Got the same question but for glass . . . ??
    Cheers,
    Mary Pozzi
    "STICK, you B*TCH!!!!!!"
    Oct 2006
    Kansas City
    Default
    Quote Originally Posted by mpozzi
    Cheers,
    Mary Pozzi
    the windows in my Hurst are acid rain etched with spots all over... nothing I have tried so far has taken them out, I think I even tried some car compound at one point.
    I bought Eastwood's glass polishing kit, but haven't tried it yet. That turns into a messy project real fast.
    Luke
    '83 Hurst/Olds
    Mar 2002
    North California
    Default
    I thought that you could also use a "clay-bar" to remove the
    water spots? I'll have to try a little spot on my side window.
    Testing...Testing.......Testing!
    -Jim
    Harriman, Tennessee
    Default
    Cheers,
    Mary Pozzi
    I had great luck with CLR and bronze wool. Not a great idea if the windows are in the car though as CLR is an acid. I soaked them for a while, then scrubbed with the bronze wool. I think I did this 2 or 3 times per window, and pretty much all of the spots came off.
    Shiny Side Up!
    Bill
    '72 442 "Inamorata"
    '89 ASC/McLaren
    Bill Kistner
    Feb 2007
    Default
    Mothers Chrome Polish.
    On the bottle "safe for glass and mirrors".
    DO NOT USE MAG AND ALUMINUM POLISH.
    In a pinch 0000 steel wool.
    Build - Drive - Destroy - Repeat
    Burleson Tx
    Default water spots
    I use a product called White Diamond milti-porpose metal polish. This stuff is the best polish I have ever used and I have used them all. It will really shine up that polished aluminum. You can get it at their website whitediamondpolish.com
    Auburn, WA
    Default
    I just use chrome polish on windows for water spots. Always works for me, and gets them REALLY clean. I'd be wary if they're tinted, though.
    Matt Jones
    Mechanical Engineer
    Art Morrison Enterprises
    Nov 2004
    Colorado
    Default
    try Bon Ami cleaner for glass. I have have had great success with it. Best to try in a inconspicous spot first.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
