    San Francisco
    Default th350 park position
    i think my shift bracket position on my th350 is in park but i'm not very sure. it's pushed forward all the way?
    1967 Chevrolet Camaro 350/350
    1962 Chevrolet Chevy II 400 194/PG
    England
    Default
    Is the gearbox shift arm aiming up or down
    Flo-rida
    Default
    one way to findout is push the car, if you hear a ping and the car wont move forward, then its in
    San Francisco
    Default
    the tranny right now is out of the car but the shift arm is pointing at an upwards angle.
    Fontana, CA
    Default
    Quote Originally Posted by TheRoaringEagle
    to the front or back?
    Nick R.
    Rochester, NY
    Default
    Dont know the answer but I think this would be easier if we used clockwise and counterclockwise terms instead of forward or backward due to different shifter arms.
    Fontana, CA
    Default
    Quote Originally Posted by matthimself456
    Good idea.
    Park is farthest clockwise when viewed from the driver's side of the trans.
    Nick R.
    San Francisco
    Default
    awesome, hehe. also i was wondering if there is an alternate solution to the bellhousing bolts on my th350. i am using repro stock bolts and the factory assembly manual says to wrench it at 25-30 lbs. ft. and i noticed the bolts taper in in the middle. it just seems very weak to me (i actually already over torqued one and broke it but luckily i could still unscrew the whole bolt out)...
    i saw some ARP bolt kits, and wondered how much more force i can use on them. Or what is recommended, what heavy duty cars have, or just some words of reassurance that these stock bolts will hold up and i am just paranoid.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
