Results 1 to 10 of 10
    Default Reducing spatter
    I have figured out how to get decent beads, no how do I reduce spatter?
    Iím not exactly sure what the wire is as it was on the welder already. I know it looks like an ER70 of some sort. I see -3 and -6 listed at a couple places stating -6 has less spatter. Might try that.
    Gas is a 85/15 mix
    Default
    I'd say you'd need to clean or replace the tip on your gun.
    Jun 2006
    Default
    go to your local welding supply store and ask for anti-spatter spray it comes in a spray bottle. if you dont have a local welding supply store try an online welding supply site. and as for your nozzle they make stuff for that too the stuff it use is kind of like wax. i like to weld a little bit to warm up the nozzle then just dip it in the jar. it has worked good for me.
    Default
    TIG weld? ;)
    Spatter is a way of life when MIG welding. Also, running a continuous bead instead of stopping and restarting an arc helps.
    Default
    Tip is brand new and I keep the gas housing nice and clean.
    Nov 2004
    Eastern Washington
    Default
    It looks to me like you dont have your settings dialed in properly. What amprage are you using? Are you keeping a low arc or a high arc?
    Feb 2006
    Default
    You might want to lower the heat a bit, you are getting some undercut. Additionally, a continuous bead, and maybe lowering the arc could help with some of the spatter.
    G-Machine
    562-595-5410
    www.gmachinestore.com
    www.gmachineracing.com (shop)
    Default
    Louie,
    Help me here, please explain undercut.
    Josh,
    I'd have to go look at the welder and try and figure out the Amperage as I did not look at the guage while laying anything down. I know it's a older 220 Snap On and I am running the heat at 9 of 12 (similar to this unit http://cgi.ebay.com/SNAP-ON-SNAP-ON-...QQcmdZViewItem)
    NY
    Default
    Quote Originally Posted by 73-TYPE-LT-LS1
    A 4 1/2" grinder with a wire wheel on it should remove all of that spatter.
    The needs of the many outweigh the needs of the few.
    Central Florida
    Default
    Quote Originally Posted by JoshStratton
    What do you mean by "low arc or a high arc?"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
