Results 41 to 54 of 54
11-26-2004 #41Registered User
- Aug 2004
- Connecticut
- 847
sorry if this is a stupid question
is it better to do your body work then go through this process because i have a 68 camaro body sitting in my garage that needs rear quarters rockers and probably other body work but it is going to sit for a while what is the best way to protect it from continuing to rust.
Paul
11-26-2004 #42Originally Posted by 68Daytona
Same here lmao-David
11-30-2004 #43
Strip-n-Dip all at one place!!!
Tell Mark that "Rich" sent ya !!!
www.redi-coat.com
Call Mark Kochanoski at 734-771-3190 or email him at:
[email protected]
He is a Chevelle guy!!!
11-30-2004 #44New to Pro-Touring
- Aug 2004
- Hattiesburg, MS
- 3
Paulk68,
Ive seen it done both ways. Dipped before any metal body work and Dipped after all welding and grinding. When I had my car dipped I choose the later. My toughts were that once the car was dipped and the rust prevention applied I did not want to apply welding and grinding heat in the chance that I would disturbe the "metal condition". I dont know if this actually makes sence but It does to my simple thinking. Alot of people dip/strip before metal work so all the problem areas are easly visable and the metal is clean for welding. If you watch American Hot Rod on TV you see that they usually strip the body to bare metal before any welding/grinding/body work.
mike
11-30-2004 #45
I'm doing all the metal work first too. I took mine down to metal first to see the problem areas. I found alot of rust i cant get to and sandblasting could not. Thast why acid is the way for me . I dont think it really matters which way. Has anyone found a place in south cali that does dipping and e-coating?
-David
11-30-2004 #46Registered User
- Aug 2004
- Jackson, MS
- 28
Hopefully his helps a few of you on the west coast.
Chris
11-30-2004 #47
Thanks chris. I'm doing a search right now
-David
11-30-2004 #48Registered User
- Aug 2004
- Jackson, MS
- 28
I just realized that will probably not help you with the ecoating like you asked...now that I think about it, the article didn't mention any ecoating. However, maybe they will know where to send you for the ecoating.
Chris
12-01-2004 #49Registered User
- Dec 2004
- San Francisco
- 13
