    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 54 of 54
    1. #41
      Connecticut
      sorry if this is a stupid question
      is it better to do your body work then go through this process because i have a 68 camaro body sitting in my garage that needs rear quarters rockers and probably other body work but it is going to sit for a while what is the best way to protect it from continuing to rust.
      Paul
    2. #42
      Mar 2003
      Make it big
      Quote Originally Posted by 68Daytona
      F70t/a, man every time I read your sig I can't get that song out of my head, lol.
      Thanks, Roger
      Same here lmao
      -David
    3. #43
      Nov 2003
      NE Ohio
      Strip-n-Dip all at one place!!!
      Tell Mark that "Rich" sent ya !!!
      www.redi-coat.com
      Call Mark Kochanoski at 734-771-3190 or email him at:
      [email protected]
      He is a Chevelle guy!!!
    4. #44
      Hattiesburg, MS
      Paulk68,
      Ive seen it done both ways. Dipped before any metal body work and Dipped after all welding and grinding. When I had my car dipped I choose the later. My toughts were that once the car was dipped and the rust prevention applied I did not want to apply welding and grinding heat in the chance that I would disturbe the "metal condition". I dont know if this actually makes sence but It does to my simple thinking. Alot of people dip/strip before metal work so all the problem areas are easly visable and the metal is clean for welding. If you watch American Hot Rod on TV you see that they usually strip the body to bare metal before any welding/grinding/body work.
      mike
    5. #45
      Mar 2003
      Make it big
      I'm doing all the metal work first too. I took mine down to metal first to see the problem areas. I found alot of rust i cant get to and sandblasting could not. Thast why acid is the way for me . I dont think it really matters which way. Has anyone found a place in south cali that does dipping and e-coating?
      -David
    6. #46
      Jackson, MS
      Forgive me for not having a lot of information because I don't have the article in front of me, but Hot Rod's current quarterly special is a Paint and Body mag. I just picked it up Sunday. In there is an article about chemical dipping at Strip Clean in Santa Ana, California (I believe that is the correct name). I will look tonight when I get home to confirm that is the correct name and if there is any additional contact information (a quick web search would probably do).
      Hopefully his helps a few of you on the west coast.
      Chris
    7. #47
      Mar 2003
      Make it big
      Thanks chris. I'm doing a search right now
      -David
    8. #48
      Jackson, MS
      I just realized that will probably not help you with the ecoating like you asked...now that I think about it, the article didn't mention any ecoating. However, maybe they will know where to send you for the ecoating.
      Chris
    9. #49
      San Francisco
      F70t/a, if you find a place, let me know 'cause I need to get my 67 dipped as well. I'm in SF and have not been able to find anybody that does it....
    10. #50
      Goggle ROCKS!! Here is their website
      http://www.metalfinishings.com/
    11. #51
      Feb 2003
      Daytona, Florida
      Zrrigid, you rock!
      Thank you Thank you!
      Roger
    12. #52
      Arlington, Tx
      Does anyone know of any place for us Texas boys ?
    13. #53
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by RedAddiction
      Good question. Our shop needs to find a place to strip & e-coat a 70 GTO Judge body that we're going to do a body-off resto on.
      Any place closer than Mississippi for us?
    14. #54
      Oswego il
      couple of links i found
      redistrip canada
      http://www.redi-strip.com/page5.htm
      article that describes how gm does their cars
      http://www.pfonline.com/articles/0104sol1.html
      this article references a shop in wisconsin
      http://www.moparmusclemagazine.com/projectbuild/5129/
      list of shops in ill, wi, fl, pa, ma
      http://www.finishing.com/188/92.html
      shop in plainfield (chicago area) ill
      ill post on yenko.net and see who they prefer
