Thread: JAG IRS opinions?
10-13-2006 #1Registered User
- Oct 2006
- 2
JAG IRS opinions?
this is may be an extreme version in a datsun 510, http://www.bryanf.com/510/rsusp.htm complete write up and it looks badass
many street rods early on used jag rear ends.
do they perform well?
how much power can the differential handle?
10-15-2006 #2Registered User- Join Date
- Oct 2006
- 2
anyone...?
10-15-2006 #3I am not sure but I think they were good back in the day,but not as good as a late model irs or 4 link.
10-15-2006 #4My understanding is that it is comparable to the rear out of a C4. I believe the weak spot is that the halfshats are also a control arm in both designs, so If you have one break, you essentially lost the upper control arm too. Unfortunately since that most likely wil happen while the vehicle is moving, that would make it difficult to control the car.
10-18-2006 #5Registered User- Join Date
- Aug 2004
- England
- 1,042
fitted 1 in a street rod they weight a ton , hub carriers are a weak point for cracking at the lower bearings , thats a deff look for quite common.
