    Results 1 to 20 of 92
      May 2006
      G-body Spohn rear sway bar on SCandC.com
      anyone try the Spohn rear swaybar like on the SCandC site ? looks similar to the H&R rear bar, looks nice and I like that its not attached to the lower arms, I'd like to know how well it would work out on a vehicle setup for handling.
      PA.
      That bar is a great setup...*for drag racing*. The rate is WAY too high for a car intended to go around corners. However, we have a ProTouring version in the works with a rate intended to compliment a 1 5/16" solid or 36mm hollow front bar. It should be a big help to folks running stiff Moog 5662 front springs in their G body too. Stay tuned. ;) Mark SC&C
      May 2006
      I thought maybe this would work, I know you told me about the swaybar you have in the works earlier this year any idea on when it might be available ? also any ideas on when the PHB 3 link setup will be done ?
      Eastern Virginia
      Hey Marcus, when do you think this road racing sway bar will be available? Does it mount like factory, or like the one pictured above? I have the 36mm front bar & 750 lb TRW S-10 springs. I assume these are similar to the Moog one.
      Scot
      86 Monte SS
      PA.
      Hi Scot,sorry for the pokey reply. It`ll be the same configuration as the one shown above. It`s the configuration GM should have used in the first place IMO. The stock G and A rear bars have a decent rate until you bolt them to the long lower arms,then the rate drops like a stone and they become relatively ineffective for their dia. I don`t have a time frame on it but it`s not a drawing board thing,the dies are being worked on now. Mark SC&C
      Eastern Virginia
      Not a problem on the timing. I had forgot all about it. But now I am thinking I want one when they come out. Any idea on a price?
      Scot
      86 Monte SS
      May 2006
      Ill be getting one when they come available, considering the quality of everything else I have gotten form Marcus I wouldn't mind being one of the first to try this one out
      Woodbine, MD
      god i love SC&C..they keep coming out with awesome stuff!!!!! when i get my $$ saved up...watch out mark...im gonna come running!!!!
      plus...i might be up there on sunday to get my other parts..you gonna be around??
      May 2006
      Hey scot got any pics of the Vette rear disc swap? do you have a functional emergency brake ? what cables did you use ? how much work was the swap overall ? did it require shock relocation
      Eastern Virginia
      Gbodyolds,
      I have the Baer brackets & shock relocation brackets. So yes it required relocating the shocks. But, I think if someone was making their own caliper brackets, you could mount them on the front side of the axle & not need to relocate the shocks. I don't have the emergency brakes hooked up yet. I need to get my @$$ in gear again & work on having some caliper mounting brackets made. You want to use F body calipers & Vette rotors. I was told to use 94-96 Impala SS E brake cables. I have them, but haven't hooked them up yet.
      Scot
      Scot
      86 Monte SS
      Oct 2006
      So Cal San Dimas Ca.
      Hey check this out, Im still going to wait for Marcus's stuff to come out though.This bar can be used on the street too..
      http://www.spottsperformance.com/suspension
      Eastern Virginia
      $500 for a sway bar kit is kindof crazy in my opinion.
      Scot
      86 Monte SS
      Oct 2006
      Quote Originally Posted by Samckitt
      LOL its not kinda crazy its hella crazy!!!!!!
      Farmington Hills, MI
      I have always wondered about the rear sway bar.
      DID I HEAR SOMETHING ABOUT A 3-LINK. I would buy that in a second.
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      Oct 2006
      three link from whom??
      This 3-link
      Quote Originally Posted by Gbodyolds
      JEFF SHORTT
      -IDEAL STEEL
      Oct 2006
      oh that three link I remember now!!
      Oct 2006
      I for get the name of the company by they sold a GNX complete rear kit but it was $$$$$$$$$$$$$$$$$$$$$$$$ but it looked real nice I did a google search on 3 link rear suspensions..
      Oh, kirban?
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      JEFF SHORTT
      -IDEAL STEEL
