Results 1 to 20 of 25
Thread: Horsepower 383 Sbc?
02-25-2006 #1
Horsepower 383 Sbc?
How much hp do you think my soon to be finished 383 actually 384.5 cu.in will make?
Edelbrock Rpm 64cc straight plug heads, Air-gap intake, Holley 750 vacuum sec, Comp cams Xe268r solid roller, 1.52 roller rockers, fully balanced engine, static compression 9.89All under 6.27 litres is a starter.
02-25-2006 #2
400-430.
02-25-2006 #3Registered User
- Dec 2004
- Dayton, Ohio
- 368
Originally Posted by 383
Hmm, I would say 445 to 455 HP. I admit that my 383 solid roller just made a little bit more.. 612 hp with dyno sheet. It is a little more radical than your build, but I had another 383 that had similar specs and it made around 455 hp on the dyno.
Jeff
02-25-2006 #4
The dyno in my head says 450 hp
02-26-2006 #5
I'm guessing in the mid 400's. That is really low compression for that engine setup.
Are you using dished pistons to get compression that low? With flattop pistons your comrpession should be in the mid 10's
Just call me Brett
02-26-2006 #6-18cc pistons are used, but the compression is a unknown for me because the engine block has been machined and i dont know by how much. The smallest number possible is 9.7 my is guess: 9.8 - 9.9
08-02-2007 #7The engine made 233 rwhp and 260hp @ flywheel everything is new or in very good condition.
What´s wrong?All under 6.27 litres is a starter.
08-03-2007 #8
