    Default painless question?
    ive got the painless harness for a 67 camaro. in the instructions it says that a few wires will be comming through the firewall. from what i can tell the only wires that are passing through the wall come through the large bulkhead connector/fuse panel. is this correct or do i have a few wires burried somewhere? thanks
    Mar 2000
    San Diego, CA
    Default
    If you are using the muscle car harness (not the Hot Rod/universal) then all the wires would pass through the bulkhead connector. At least this was the case with my '69 harness. Good luck.
    Mike Schwartz aka chevymike
    1955 Chevy 210 Wagon
    1965 Chevy C10 Panel Truck
    1972 Chevy El Camino
    Default
    ok, that makes sense seeing as how i spent 1/2 an hour last night looking for these syupposed wires that just arent there. thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
