    Page 9 of 9 FirstFirst ... 4 5 6 7 8 9
    Results 161 to 167 of 167
    1. #161
      Aug 2023
      I had 3.08 gears with a Wide ratio Muncie.
      I know she's going to scream more with the 3.73 than a 3.36 but may be a little more fun to drive.
    2. #162
      Jan 2014
      Austin, TX
      you'll be fine....I drove mine from VA to TX with the close ratio muncie and the 3.73s....RPM was obviously on the high side, about 3K at 75 mph but the Corvette Central exhaust with the MagnaFlow mufflers was amazingly compliant. Really smooth and mellow, even cruising at 3K for hours on end.
      1972 C20 Suburban
      1964 Corvette Coupe
    3. #163
      Aug 2023
      Quote Originally Posted by FLYNAVY53 View Post
      Finally back at it....
      Heres the new steering wheel installed
      Attachment 163980.
      I know it was a while ago, I was wanting to use a 69 steering wheel also, I bought one and noticed it does not sit flush on the boss like the original. How did you get it to fit and not make the horn honk?
      Did you have to bend the horn contact or shim it?
    4. #164
      Jan 2014
      Austin, TX
      Assuming your '69 wheel looks like this:
      You need a shim that looks like this:
      Name:  48230701d1512100251_steering_wheel_spacer_allows_the_c3_smaller_diameter_steering_wheel_on_63_66.jpg
      I got mine from a Corvette Forum member a few years back....Tom Shelby (Sky65). Dont know if he has any left, but if he doesnt, allegedly a standard plastic light switch cover from Home Depot is the exact thickness you need to make your own shim. I think Id be inclined to take some measurements, draw it up in CAD, and send the file to Send-Cut-Send and have them cut it out of the proper thickness of aluminum before I'd use the plastic light switch cover.
      1972 C20 Suburban
      1964 Corvette Coupe
    5. #165
      Aug 2023
      Thanks! I'll contact Tom
      Update Tom had another!!
    6. #166
      Aug 2023
      Did you get those body mounts replaced?
    7. #167
      Jan 2014
      Austin, TX
      Unfortunately not yet. The project kinda stalled over the holidays and we’ve been surprisingly busy this spring. Hoping to get back on it shortly .
      1972 C20 Suburban
      1964 Corvette Coupe
