    Results 1 to 11 of 11
      LS Engines 4.8, 5.3, 5.7, 6.0 and 8.1
      is there any simmilarities between the 6.0 and smaller engines and the 8.1 like can we use parts on the 8.1 that were made for the 5.7??
      Nov 2004
      NW Arkansas
      I know that parts on the 5.3 5.7 6.0 will interchange as far as the 4.8 and 8.1 I have no idea but I would assume that they would
      Jun 2002
      Long Island, NY
      I'm pretty sure the parts on the 4.8 and 8.1 will not interchange, but I may be wrong? As Travis said, 5.3, 5.7, 6.0 are mostly all interchangeable.
      absecon, new jersey
      some parts will interchange with the 4.8 also, its the same block as the 5.3 with different stroke.all the timing covers,valve covers,rear covers intakes and oil pans will interchange,the waterpumps are different because of the top inlet from truck 4.8 and 5.3 to ls1 5.7's.
      http://www.ls1tech.com/forums/showpo...82&postcount=4
      73 corvette chop top silver LS6 motor ,LS6 intake,700r4,2400 pro torque convertor ,3.70 gears,modified hooker sidepipes to fit LS1,17 x9.5 boyd starburst,nitto 275/50/17-255/50/17 tires,vb&p suspension,nitrous,L-88 headlights,autometer guages.L88 hood,flares,spreader bar,vb&p sway bars
      so by that I could use pratically any part made for the 5.7 on the 8.1 such as the Fast LSX intake manifold
      mo
      8.1 (502)is a big block ,the rest are small blocks
      absecon, new jersey
      yeah the 8.1 is different like he said only the 4.8,5.3,5.7 and 6.0 will interchange most parts not all.
      I know it is a big block, it is a gen 3 like the ls1 variety or is it a just different enough it being a big block so the intake manifold and stuff like that won't interchange
      absecon, new jersey
      Heres a 8.1 looking at it you can tell nothing looks the same as a lsx type motor.I doubt the intake will swap over.
      http://cgi.ebay.com/ebaymotors/2001-...QQcmdZViewItem
      thanks nitrovette it appears to me that the 8.1L is a gen 2 big block, so it appears the 8.1 and 6.0 are two totally different engines
      Quote Originally Posted by killer_datsun
      Correct.
      Instagram @projectgattago
      Dr. EFI
