    Results 1 to 18 of 18
      Oct 2007
      First gen camaro ls swap air intake options
      Anyone know of a member or shop that Fabs up air intakes ?
      i like so r things about rotofab https://www.roto-fab.com/1967-69-cam...old-air-intake
      And air aid
      https://www.jegs.com/i/Airaid/028/101-400/10002/-1
      but I wanted to see if their were other options
      thank you
      67 Camaro In progress
      Oct 2007
      Dec 2009
      Brunswick, GA
      I built this for my car. Sheet metal is from Lowes $15. Powdercoating is $20. 22 degree pipe from eBay for $65. Filter was $40 from eBay. Lexan was $20 from Home Depot. Just use cardboard mocking everything up before cutting everything. I made mine for somewhere around 175 all together.
      1967 Camaro RS/SS - Project "Skunkworks" in Progress...
      Oct 2007
      Looks great did you roll the tube from sheet metal
      Aug 2010
      Richmond , Tx
      Country Flag: Philippines
      Quote Originally Posted by XLexusTech View Post
      And air aid
      thank you
      I found a Rotofab on ebay for less than $200 couldn't be happier on fit and finish
      69 Camaro LS2, ridetech 4 link fikse wheels yada yada yada
      17 Grand Sport
      Oct 2007
      Quote Originally Posted by jamminj007 View Post
      Wow that’s cheap ! I really like it as well but I read it doesn’t fit with the griffin radiator
      Dec 2009
      Brunswick, GA
      I bought a 22.5 degree spectre tube and went with it. Keep in mind all the kits are for the low profile factory style intake. If you have anything else you will have to modify the kit to fit. I didn't want to spend that much on the rotofab kit just to have to mod it.
      Oct 2007
      Quote Originally Posted by piratebaseball View Post
      Just ordered parts
      Dec 2009
      Brunswick, GA
      Just ordered parts
      Cool deal. What did you end up going with? And please post pics when you have it done.
      Nov 2014
      I used the following parts: Spectre 97990, 9771, 97290, and KN RE-870. Total price $154 from Amazon. IAT was installed with a grommet i had laying around. Clearance is tight, but no troubles yet.Name:  20180224_144030.jpg
      Oct 2007
      Quote Originally Posted by btmatt View Post
      Nice , looking up the part numbers 97290 is 3 inch did you mis key or did you reduce to 3 inch ?
      Nov 2014
      hmm, that is odd. I checked my orders on Amazon and the part numbers are correct. The tubing is indeed 4". On a hunch, I checked with Spectre and 97290 is listed as 4" diameter. I guess that Amazon has their description wrong; funny I did not notice that before.
      Also, I did not mention, but the bellows on the TB came from a cold air intake off the kid's truck. I also fabricated a tab/stand that attached to the inner fender and rests under the air cleaner clamp to support the air cleaner. IA temps typically run ambient as long as the car is moving and have not experienced any serious heat soak in south Texas heat
      Mar 2013
      Sunny Calif
      killer set up!
      Mar 2013
      Napier, New Zealand
      Country Flag: New Zealand
      3D printed my own otr from ABS plastic
      Damien
      Napier, New Zealand
      Project Page: https://www.pro-touring.com/showthread.php?99096-Project-Camaro-68-P-T-Muscle
      Next Project: 1956 Chevy Truck, Full C3 Suspension, Nascar Inspired
      Mar 2013
      Sunny Calif
      Quote Originally Posted by Tweak View Post
      you need to recreate the kit an market it.
      if so im in because i would love to add this set up to mine!
      Chicago suburbs
      You made that??
      Looks awesome, very original!
      I'd buy one...
      Mar 2013
      Sunny Calif
      air raid kit with a couple of step down silicone sleeves and tucked behind the cocktail shakers
      Jul 2010
      south gate
      I’m Selling some 1967-1969 mandrel bent real cold air intake in the for sale classifieds section https://www.pro-touring.com/threads/...ld-air-intakes
