    Results 1 to 20 of 31
      Apr 2015
      1969 camaro wide fender
      I am looking to at subframe options with the idea of 315 front tire. Wanted to stay with stock fenders, but nay need to consider wider front fender. the anvil fenders look good, cost a bit, and have a wait to produce. Haven't found any other wide fender being produced. Thinking about modifying a new metal fender and want to look stock in appearance. Probably need good inch to inch and a half wider than stock. Any with anvil fenders? other options?
      1969 Camaro rs
      ls3 427
      Mountain Springs, Texas
      I have Anvil fenders. I stretched my rear quarters to match using the technique in this thread which also shows fender stretches:
      http://lateral-g.net/forums/showthread.php?t=23832
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Apr 2015
      Was the front fit overall good?
      1969 Camaro rs
      ls3 427
      Fit was pretty good. Mine are fiberglass so they did need a little work to prep for paint. I used all Anvil parts on the front end with the exception of a Ring Brothers hood.
      Don
      Quote Originally Posted by sean69cam View Post
      Apr 2015
      Looks like you have the rs headlights. Did the fenders already have the two tabs that the outer headlight mounts
      1969 Camaro rs
      ls3 427
      Yep.
      Dec 2010
      Fredericksburg, VA.
      Your 69 is looking great Don! I just wish someone made wide front fenders for the 68.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
      Don
      Attachment 152821Attachment 152822
      The car is looking good Don! Wow!!
      Thanks guys. Car is on hold while I do a 57 Nomad and a 69 Camaro. Hope to get it finished this fall and drive the wheels off it...
      Don
      I think it would be relatively easy to widen a set of 68 metal fenders so long as you only wanted an inch or so of extra width.
      Don
      Dec 2010
      Fredericksburg, VA.
      Don
      It might not be a big deal for a body man, problem is I'm not a body man and have no idea where to start. Anvil indicated they are not interested in offering wide fenders for the 67/68. I have reached out to both BOS and JCG but have not received any reply from either. I just can't seem to find anyone interested in talking to me about widening a pair of 68 fenders. I may just order a pair of AMD fenders, start cutting and see what I end up with.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Do you want a simple flare of the wheel opening or more like a widebody stretch?
      There is a lot of videos on YouTube.
      Don
      Dec 2010
      Fredericksburg, VA.
      Basically, I want to keep the profile of the stock fender well lip just make it about 1.5 wider. I don't want it to be obvious that the fender is wider. No bolt on flares or anything that looks add on. I really really like the fenders on the one lap Camaro of James Shipka's 67 and that is why I tried to get in touch with BOS. Locally, there is nothing but collision repair shops that only know how to bolt on parts and squirt paint. I will just keep poking around and sooner or later I will find someone.
      Steve Hayes
      "Dust Off"
      68 Camaro
      So stretched like this. Looks like it might take four fenders to make two. I am not a metalshaping guru but it looks like maybe they used a planishing hammer to stretch the fender.
      Don
      Connecticut
      Don
      Damn that is a nice looking car Don, what color white did you use?
      Paul Krol
      1968 Camaro
      Hi Paul. Hope things are going well with you. The color is SPI pure white.
      https://www.southernpolyurethanes.com
      Don
      Dec 2010
      Fredericksburg, VA.
      Don
      Yes, that's what I'm looking for. Unfortunately, that kind of metal work is way beyond my skill set. I just need to find someone to make me a pair.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Metamora, Illinois
      Don
      What size tire do you estimate the widebody fenders allow you to run with a stock frame?
      Feb 2011
      dallas, tx
      steve count me in if you find a set. I would like to pull my front fenders out another 1 1/2" to run 315/30/18 on all 4 corners. but i want them to look like the post dhutton posted.
      Here’s another way to do it
      Don
