05-12-2018 #1Registered User
- May 2018
- 2
Wilwood Master Cylinder & No Pedal
Hey people.
So I decided to upgrade my setup and pulled the trigger on a Wilwood MC.
So here's my problem, I did the standard issue bench bleed, and install, but after all the bleeding, the pedal still goes to the floor.
I know there is no air in the system. I read somewhere (jalopnik, or a C10 page... can't remember) that a guy suggested that the front piston in the MC may be stuck or vacuum locked in the forward position.
He suggested blocking the front port and see if I have pedal, and I do. My question is, if thats what it is, how do I get the front piston to release?
Kinda of new to the performance side of things, so thanks for any help you guys can give me.
Matt
05-12-2018 #2I am assuming the bore size is the same and you verified there are no leaks anywhere? I just went through something similar when I swapped out a Wilwood MC for a Baer Remaster MC. I had to adjust the master cylinder pushrod to get a pedal with the Baer Remaster. Are you running manual, power or a hydraboost setup?
05-12-2018 #3
