    Results 1 to 12 of 12
      Feb 2012
      Mocksville, NC
      Multiple battery post connectors
      With all the electrical crap constantly being added to our cars and for some reason EVERYTHING must be routed to the battery, does anyone make a multiple connector to the battery posts? I've seen a 4 connector terminal that the stereo guys use but I have the typical 1 gauge battery wire and 2/0 welding cable from the alternator, EFI wires, and 2 other wires for some other crap I wired up. Any way to dress these terminals up? My battery cover helps but when I take it off, kinda looks like **** in there. Thanks and sorry for the cussin'.
      1968 Charger R/T, EFI,SC,6-speed
      Jan 2013
      Abbotsford, B.C.
      You can run a single 0/1 gauge off the battery to a terminal bus and have all your accessories run off of that. Cleans up the battery post.
      Apr 2013
      Here is a multi connection battery post.
      Tim john---
      Why not do what modern cars do? Most new cars have a power distribution block that is fed by a dedicated connection directly to the battery. They usually contain a combination of fuses and relays. I like the various Delphi options. Go to the junk yard and start poking under the hoods of 90s GM cars.
      Oct 2014
      DFW, Texas
      I have one ground wire going from the post to the chassis. My EFI car does everything just fine with it being chassis grounded.
      I have many ground straps around the car, but that's it, nothing fancy.
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Fredericksburg, VA.
      When these accessories tell you to connect directly to the battery they mean electrically not literally. Do what Andrew said, just run a dedicated cable to a conveniently located fused distribution block or two.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Feb 2012
      Mocksville, NC
      Good deal. Thanks again for the help.
      Chit-ca-go
      When they refer directly to battery, it typically means a fused dedicated (not shared) circuit at battery. If you had unused circuits in your fuse panel for example, this would be sufficient provided that the amp rating and wire size (gauge) are correct to protect it. If you have an updated harness, it should have several free circuits. Original ones may as well, but adding the supporting wiring can be difficult. An aftermarket amplified stereo system is something that would require a direct battery connection.
      1971 Firebird
      2017 Slipstream SS
      Orange County, CA
      Here is a nice fused distribution block
      Jul 2015
      Feb 2012
      Mocksville, NC
      Very nice. Thanks for all the input as usual.
      May 2019
      Pensacola,Fl.
