      Oct 2007
      full throttle signal fly by wire
      Hey folks. Wiring the vintage air today ,,, thief is a full throttle wire which will cutoff the compressor on full throttle
      Has anyone used this? Where can I pickup full throttle signal?
      Ls3 psi conversion harness ... fly by wire
      67 Camaro In progress
      I would incorporate a Lokar switch into the pedal bracket to generate the signal
      https://www.summitracing.com/parts/l...CABEgLA6fD_BwE
      Jun 2010
      Deployed
      So, I did not install one of these. Why would you need it? RPMs kill the compressor not WOT. If you plan to blast the engine to 7000rpms, turn the AC off.
      1970 Camaro/DSE build
      Jun 2011
      Brooklyn, NY
      Use a window switch off the tach
      Quote Originally Posted by 12sec ss View Post
      Load and RPM are not the same thing. Presumably he wants the compressor off at WOT, even if at 2000rpm. How does an RPM window switch do that?
      Mar 2016
      What pcm are you using? let it give whatever signal you need like the OEM does.
