    Results 1 to 1 of 1
      Nov 2012
      Sacramento, CA
      2018 Speedway Floater Rear End Promotion
      2018 Speedway Engineering Floater Rear End Promotion
      Buy any Speedway Engineering Floater Rear End
      & Speedway Engineering Will Buy You a Ticket to the
      2018 Ron Sutton Workshop of Your Choice
      Previous Speedway promos worked so well, we agreed to offer this for 2018 Ron Sutton Workshops also.
      Speedway Engineering is a proud partner for 2018 Ron Sutton Workshop Tour. They are one of eighteen sponsors of the Ron Sutton 7 Secrets of Total Car Performance Workshop series that helped to bring the ticket price down from $1500 to only $349. If you’re in the market for the best 9” Ford based floater rear end in racing & Pro-Touring … and act now … the ticket won’t even cost you that.
      Ron Sutton Race Technology
      is a long time Speedway Engineering Dealer and can help you get the details & dimensions for your rear end order spot on. Don’t worry about figuring out the width, pinion offset & brackets on your own. Contact Dave Hanson & work out your ultimate rear end together. 844-722-3832 Ext 1
      Complete Speedway Engineering 9" Ford Mod-Lite Floater Assembly - Only $1359
      • Brand New SVO Ford 9” Housing (10 gauge)
      • Vent, Fill & Drain Plug Fittings
      • 3” O.D. x .188” Wall 1020 DOM Axle Tubes – Max Surface Welded
      • Premium Alloy Steel Axles, Double Heat Treated & Polished
      • 4140 Heat Treated, CNC Machined Hubs Snouts TIG Welded
      • Forged 4140 Steel, Heat Treated Hubs with Bearings & Seals
      • 8620 Steel Heat Treated Drive Plates - 2.50” Centric Snout Fits Most Wheels
      • Total weight around 76#
      • Lug pattern options: 5x5”, 5x4.75” & 5x4.5”
      • Stud Options: 1/2” or 5/8” – Short or Long
      More Options & Info on Mod-Lite Floaters HERE & Grand National Floaters HERE
      Ron Sutton Race Technology Options:
      • 7 Brake Package Options from Wilwood & StopTech - With or Without Parking Brake
      • Shipped Bare or with Suspension Brackets Welded On
      • Inner seals, aluminum hubs, HD Drive Plates, lightweight axles, cambered hubs, etc.
      • Custom Built 3rd Members with Soft Spring Lockers or Tru-Trac Differentials (See them HERE)
      Notes:
      • 50% Deposit on Rear End Required to be Eligible for Workshop Ticket
      • PIF Required Before Building Commences on Custom Rear Ends
      • Workshop Ticket is NOT-Transferable, nor resellable to another Person
      • Tickets Available for all 2018 Workshops:
      • Jasper, IN - April 22nd
      • Columbus, OH - July 5th
      • Ft. Worth, Texas - Sept 27th
      • Charlotte, NC - Oct 18th
      • Las Vegas, NV - Oct 31st
      For more information on Speedway Engineering Floater Rear Ends – Contact Ron Sutton Race Technology:
      Phone: (844) 722-3832 Ext 1
      Address: 11345 Trade Center Drive, Suite 450, Rancho Cordova, CA 95742
      Website: www.RonSuttonRaceTechnology.com
      Not buying a Floater Rear End but want info on the Workshops? Go HERE.
