      Jan 2012
      5 rib vs 6 rib serpentine belt
      I have a serpentine belt question. In my 66 Chevelle I have an LS3 with Vintage Air and a Holley Accessory Drive Kit. I have about 1,200miles on the engine and I have eaten two belts. Basically, the AC side rubs the outer (front) groove out of the 6 rib serpentine belt to make it a 5 rib belt.
      On the drivers side the belt will be on the back 5 ribs, and on the AC side the belt is on the front 5 ribs. I tried putting the bely on theback on the AC side and it squeaks terribly.
      I have run the car about 300 miles with the 5 rib belt, no issues. So, my question is, should I just leave it? And if I need to fix it,how, I think it is lined up, but clearly not.
      Appreciate any help.
      Rpm66
      I would dig deeper and find the source of misalignment. Could be something as simple as a missed washer.
      Instagram @projectgattago
      Dr. EFI
      Jan 2012
      I went through the directions from Holley, actually the washers were wrong, the shop I had the car at added one. Turns out that if I put it by the book, it squeaks even worse. Anyone know someone in NC that is good at this type of thing?
      Jan 2012
      I think GM Performance has a bracket that mounts the AC high on the passenger side. Has anyone done this? Sure could use the part number.
      rpm66
      Rodger Moore
      Aberdeen, NC
      1966 Chevelle
      LS3 / T56
      Dec 2010
      Fredericksburg, VA.
      Clearly something is not aligned correctly despite what the instructions say. Have you called Holley? You also may need to use a laser to check the pulley alignment.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
      Jan 2012
      Steve,
      We did use the laser, of course I'm not sure the capability of the guys using it.
      I ended up calling Holley, they sent me 2 washers that they say fix 99.9% of the problems. I'll know in a few days.
      Rodger
      Rodger Moore
      Aberdeen, NC
      1966 Chevelle
      LS3 / T56
      Mar 2013
      Sunny Calif
      had similar issue, wound up being my alternator bracket needed spaced out via 3 washer mounting points only after it ate a belt and ripped the wires out of my mass air sensor.
