    Results 1 to 20 of 28
      Jun 2010
      Deployed
      Need Fellow Las Vegas Welder
      Looking to pay someone to install my DSE roll car. Anyone know someone?
      1970 Camaro/DSE build
      Jul 2016
      Yup. Angel. Seven zero 2 nine 85 six 6 0 1. He will come to you
      1986 Saleen, Aluminum block 408W, T56, Full Griggs Racing supension
      Mar 2010
      Orange County, CA
      I've been watching this guy's youtube videos for a while and he's a great fabricator, definitely worth giving him a call.
      http://thefabricatorseries.com/
      Jun 2010
      Deployed
      Is Angel a business? Does he have a website?
      Jun 2010
      Deployed
      Any more in this? I can’t find anyone who has experience.
      Jun 2010
      Deployed
      Quote Originally Posted by Curt C View Post
      Can I use you as the referred by?
      May 2010
      kitchener,Ontario,Canada
      I'd go to the one suggested by oldskool442 his YouTube videos will make your head spin and hes not far from the strip
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Jun 2010
      Deployed
      So this guy ^^ mainly just teaches...I got a hole of Angel and going to give him a go next week after SEMA. Anyone here have work done by him as well?
      Jun 2010
      Deployed
      "ANGEL"
      Team, don't go to this guy to install your expensive Detroit Speed parts. He can't follow instructions and I just lost $1500 over it.
      "ANGEL"
      That's unfortunate. Nothing worse than someone that thinks they know everything and just does stuff without consulting the instruction manual.
      Instagram @projectgattago
      Dr. EFI
      Jun 2010
      Deployed
      How does this look? I tried to clean it up, can this be visually fixed? He burned through the floor and basically puddled everything.
      corona,ca.
      I'd cut the main hoop with a 7.00 cutoff wheel on a grinder,and ask Detroit speed to send you new plates and start over.
      The appearance should bother you, but more should be if penetration was poor thats more of a problem.
      For $1500 you were better off buying a mig welder and doing it yourself.
      Make sure to use a ratchet strap around the hoop when you cut and weld it in.
      - - - Updated - - -
      Do you have pictures of the rear down bars too?
      Did this guy Angel use a 110 welder or a 220volt?
      72 chevelle.
      Jun 2010
      Deployed
      Quote Originally Posted by chevelletiger View Post
      - - - Updated - - -
      I'm not sure...He said it was a big miller welder when we set up the appointment. He is mobile too if required, but told to come by the shop because his welder wasn't portable.
      What do you mean use a ratchet strap?
      - - - Updated - - -
      Here are the pics.
      His welding seems fine. It just sucks that he didn't put things in the right place.
      Dr. EFI
      Nov 2016
      Sulphur, La
      The problem is going to be cutting the down tubes off of the main hoop without messing up the hoop. Obviously the down bars will then be too short as well. Personally if I was going to re-do that I would re-use the plates and replace all the tube. You can use those as guides for bending the new stuff so you don't have to buy it all again.
      Jun 2010
      Deployed
      Right now Detroit Speed is working on a quote for new tubes. I'm very hesitant on who to take it to now for a proper install.
      Jul 2016
      Oh man, I feel your pain. Get a hold of John, he is a mod over at Team Camaro and he lives in Las Vegas and does Pro-Touring mods for guys. A Great Guy !!!! Tell him Donny from the Team Camaro forum recommended him to you. If he can't help he will def know who to go to.
      Jun 2010
      Deployed
      More awesomeness.
      Jul 2016
      You can grind those down and have someone Tig them instead of Mig. I told John (Team Camaro) about your situation. Good Car Guy to know in Vegas. "Vegas69" is his screen name. Good luck.
      Jun 2010
      Deployed
      Quote Originally Posted by DT69Cam View Post
      This is what it looks like now...
