Results 1 to 12 of 12
Thread: O.E. TR6060 to Magnum ?s.
03-20-2018 #1Registered User
- Mar 2018
- 2
Looking to use a used TR6060 from a Chevy Camaro, Dodge Chally, or a Pontiac G8.
Looks like the Chally, and G8 have the same 1-4 gear ratios as the Magnum, that away I could use the Magnum input shaft. Then change out the mid plate, main shaft and tailhousing to the Magnum setup. I would like to use the LS1 T56 bellhousing, and ls1 clutch setup.
Or use the Camaro Tr6060, just change out the main shaft, and tail housing.
Not sure what direction to go, it comes down to price and if plausible. Not sure where to find Input shafts lengths, and gear tooth count.
Thanks.
