    Results 21 to 40 of 60
    1. #21
      Nov 2012
      Sacramento, CA
      Car Year & Model: 70 Plymouth Cuda
      Competing in: optima Ultimate Street Car & Road Course Track Days
      Front Clip/Suspension: TA Track-Warrior Front Clip
      Rear Clip/Suspension: GT Track-Warrior Rear Clip
      Engine: Twin Turbo 488" R3 Dodge NASCAR Engine
      Trans: T56 6-speed
      Brakes: StopTech 14” ST60/ST40
      Owner: Craig Scholl
      Builder: Craig Scholl
      Here are a variety of photos from Craig Scholl amazing Track-Warrior build of this 70 Cuda. Front frame clip & suspension first.
      This is where the idea came from for our adjustable shock mounting fixture we offer today HERE. And this is the reason we call it the "Scholl Fixture."
      The Ron Sutton Race Technology shock controlled, decoupled 3-Link & Watt's Rear Suspension with Craig's cage structure.
    2. #22
      Nov 2012
      Sacramento, CA
      Car Year & Model: 70 Ford Mustang Fastback
      Competing in: NASA TTU & Track Days
      Front Clip/Suspension: GT Track-Warrior
      Engine: Track-Warrior 3 LS7 700 HP
      Trans: Sequential Shift T56 6-Speed
      Owner: Greg Weld
      Builder: Randy Chastain – One Off Customs
      More photos with update on the Track-Warrior roll cage structure ... and first glimpse of the backbone structure we use in our GT & TA Track-Warriors.
      We now offer a tool we call the Scholl Fixture, named after Craig Scholl that gave us the idea when he created his own. In these photos, you can see how we use it to place the slant top boss that welds top the roll cage bars. This insures the boss, and the jack screw that threads into it, is parallel with the shock at ride height. The tool is adjustable in height for any shock height we use. The rubber donut on it is 3.5" OD ... the same as the OD of coil over springs ... so we can check for & maximize clearance before we weld it in. While we have these tools for sale in our Catalog HERE ... we "loan" these to our clients that buy Track-Warrior clips to insure they weld the adjustable shock mounts in true.
      Name:  Scholl Fixture Side View.jpg
      Name:  Scholl Fixture Front View.jpg
    3. #23
      #becauseracecars
      Instagram @projectgattago
      Dr. EFI
    4. #24
      Nov 2012
      Sacramento, CA
      #becauseracecars
      For sure ! At least the 70 Mustang is. It will only be a fun "Track Car" & occasionally race in NASA's unlimited classes.
      Many of our clients building Track-Warriors are doing the "Race Car with license plates" thing.
    5. #25
      Nov 2012
      Sacramento, CA
      Car Year & Model: 1965 Buick Wildcat
      Competing in: Track Days, Autocross, optima planned
      Front Clip/Suspension: RSRT GT Track-Warrior
      Rear Clip/Suspension: Custom Torque Arm
      Engine: Built Buick 455 Dry Sump
      Trans:Tremec 6-Speed
      Brakes: Wilwood
      Owner: Jeff Peoples
      Builder: Jeff Peoples
      Jeff Peoples is an awesome guy, client & friend down in Mississippi that is building the coolest 1965 Buick Wildcat I've ever seen. Being a "Buick guy" ... he is keeping the engine real Buick ... but it's a strong one with over 600 HP.
      We met as he was correcting some things from a previous builder that needed fixing. Jeff decided to replace the front end with the highest grip front end he could find ... and get bigger tires in the front ... to match his rears. 315's all the way around for awesome grip & turning.
      Jeff purchased the RSRT Track-Warrior clip in the GT variety. That is my highest grip front suspension design ... but requires the engine to be set back ... a lot. The lower front pulley needs to be behind the FACL (Front Axle Centerline). Here are some photos of his build as well as renderings of his target finished look.
      Name:  Jeff Peoples (2).JPG
      Name:  Jeff Peoples (1).JPG
      Name:  Jeff Peoples (4).JPG
      Name:  Jeff Peoples (9).JPG
    6. #26
      Mar 2018
      69 torino
      Car Year & Model: 69 Ford Torino
      Competing in: Road Course Track Days
      Engine: Aluminum Ford FE 428" 750 HP
      Trans: T56 6-Speed
      Owner: Mark Milliron
      Here are some pictures of the 69 Torino roll cage
    7. #27
      Nov 2012
      Sacramento, CA
      My unfinished 57 Chevy Track-Warrior Project is for sale.
      You can finish it, or we can have Randy Chastain at One-Off-Customs finish it to whatever degree you want.
      * Same shop building Greg Weld's Mustang & Mark Milliron's Torino.
      Smoking Deal ! Get all the details here: http://lateral-g.net/forums/showthre...151#post676151
    8. #28
      Sep 2007
      Brunswick, GA
      Loving this thread and all the different build styles going on! Thanks and please keep it going Ron!
      Chris Ronson
      -1967 Camaro SS
      -1966 LeMans - Project "Last Breath" (breaking ground 2017)
    9. #29
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by SIK02SS View Post
      Hey Chris! Thanks for chiming in. I see all the views & know people are checking the thread out all the time. But I found it odd no one was commenting or asking questions.
      Hey y'all! Feel free to chime in with comments or questions.
    10. #30
      Jun 2012
      South Lyon, MI
      Ron,
      First off, this is a cool thread with a lot to look and and learn.
      Second, I have a question regarding the transmission tunnels. It seems that there is a lot of structure between the transmission tunnels and the rocker panel to support the floor and to provide safety. There is some reasonably stiff structure over the top of the transmission tunnels. However, from what I see here, the bottom is open.
      I am building what is essentially a structural transmission tunnel that looks similar to some of these. However, I plan to enclose the bottom to some degree to give it more torsional stiffness. Will you be adding anything under the transmission and driveshaft to do the same?
      I am basing this concept on a lot of Collin Chapman's designs form the Lotus Seven up though the Europa that had a structural backbone in the car to keep it torsionally rigid. I will have a roll cage for rollover protection and to comply with governing body safety regulations. Maybe I am just over-engineering the project.
      It is a 1974 Nova. So it was pretty flexible from the factory. I want the frame to be very rigid so the suspension can work properly.
      Any thoughts?
    11. #31
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by cornfedbill View Post
      Ron,
      Any thoughts?
      Great question Bill. I need more info to give you a correct answer. What do you plan to do as far as roll cage & other frame structure?
    12. #32
      Jun 2012
      South Lyon, MI
      Quote Originally Posted by Ron Sutton View Post
      It will have a 4 point rollbar this year for sure, but will eventually have a 6 point cage with door bars.
      I am connecting the subframe back to the rear suspension. I have channeled the body over the subframe, so it will be welded to the floor. It protrudes about 1 inch up through the stock floor pan. Everything between the stock frame rails will come out and be replaced with a structure not unlike what you have done in some of these examples.
      I will run 2X2 16 gauge tubing down each side of the transmission tunnel from the front suspension to the rear suspension. On top of that I am building a structure of square and round tubing that will be similar to a Lotus Seven backbone.
    13. #33
      Nov 2012
      Sacramento, CA
      Gotcha. I'll break my answer into two parts.
      A. Yes, adding structure under the trans tunnel will increase chassis rigidity. But, will make working on the car harder.
      B. You have a lot of other options that would not make the car harder to work on, and add more structural rigidity than the bracing under the tunnel. Running a roll cage that ties the front subframe into the car better is the best, most valuable area to strengthen.
      Under the trans tunnel is less important, than stiffening the front chassis area, in my experience. We load the front end the most.
    14. #34
      Jun 2012
      South Lyon, MI
      Ron,
      Thank you for your kind advice and your time.
    15. #35
      Nov 2012
      Sacramento, CA
      Competing in: Track Car & Occasional NASA TTU races
      Trans: PPG Sequential Shift T56 6-Speed
      Owner: Greg Weld
      I've been so busy with client projects I haven't posted photos for quite awhile. In that time a LOT of progress has taken place on Greg Weld's 70 Fastback Mustang Track-Warrior. Here are a LOT of photos.
      Feel free to ask questions about any part of the build.
      RR Air Jax shown. The 4 bosses welde to the main hoop are for the battery box. You can see the slotted lower 3-Link mounts. This lets us get the lower links perfectly level for zero rear steer. And we can adjust them up for positive rear steer (turn better on tight corners), or down for counter rear steer (more rear grip on fast sweeping corners).
      Name:  Photo Apr 05, 10 29 29 AM.jpg
      Here you see the whole powertrain inside the tunnel, as well as the exhaust. All of the exhaust will be coated inside & out with Jet-Hot's 2000° thermal barrier coatings to contain the heat inside the exhaust, where it needs to be, while protecting the transmission & driver in the cockpit.
      Name:  Photo Apr 10, 5 04 12 PM.jpg
      Our Slotted steering column mount lets us place the steering column in the best location. We use 3 u-joints in our columns. One at the rack, the second you see to the right of the mount & a third, just inside the firewall. This allows us to make the steering column "tilt" inside the cockpit to driver preference, without affecting the mounting location in the engine bay.
      The RSRT tabs on the front of the monster 2.5" OD sway bar tube hold either 2" or 3" poly bushings for the radiator to sit in. The bracket with the 10 little holes will mount the front end "receiver" ... and can be adjusted up or down after install.
      There are something like 72 lightweight Dzus fastener tabs on the bottom side of the chassis to mount the smooth belly pan & diffuser.
      Just mocking up steel floor panels after the pedals are all in place.
      Every shop needs a "Shop Dog". Layla is the most "chill" dog ever.
      The aluminum panel INSIDE the cockpit is rubber mounted to insulate the ECU & other electronics from NVH. The two light tabs in the upper right mount the ARE dry sump breather. The 4 below ... two on the cross tube & two on the frame that are hard to see ... mount the ARE 2.7 gallon dry sump tank.
      Passenger side cockpit
      Pedals (Brake & Clutch are Wilwood) Throttle is a GM Corvette DBW
      Battery Box installed. We use a zinc "removable" battery box because ...
      1. Zinc will "resist" battery corrosion longer than paint or powder coat
      2. Eventually, it will corrode & look like crap ... and a new one can be bolted in.
    16. #36
      Nov 2012
      Sacramento, CA
      Owner: Greg Weld
      Greg Weld came & sit in the car for a seat, belt, pedal, switches, fire handle, steering & shifter fitting.
      The man, the myth, the legend that is Greg Weld. LOL
      In all seriousness, it was great to see Greg. For those that don't know, he is battling cancer ... again ... in a different area.
      Name:  GW in Seat.jpg
      Fitting went well. We work out seat position first ... relative to the pedals. Then we dialed in the steering wheel location ... switches, fire pull handle, shifter, etc.
      The orange thingy in the upper left is the Air Jax "Wand". You push it into the fitting to lift the car. Then tap it & pull it out to lower the car. This particular system is my favorite, because it uses Big Bore jacks. That let's us utilize lower nitrogen pressures. 150 psi lifts a 2900# car. 200 psi lifts a 3850# car. 250 psi lifts a 4800# car.
      In this photo, you can also see the fire suppression bottle & the FAST driver cooling system to provide cool water to the driver's cool suit & cool air to the driver's helmet. Anyone that has done this knows the cockpit can be 40° hotter than the air temperature on track days. Keeping the driver cool ... to be safe, drive better & have more fun ... costs about $1500.
      Name:  GW in Seat 2.jpg
      Two things have saved more lives than ANY other safety device in the last 20 years ... HANS devices & full containment seats like you see here.
      This one is a heavy duty ButlerBuilt road race seat spec'd by me, with head & shoulder supports (to prevent injury/death in side impacts) and set back headrest (to provide room for HANS). Best protection available for $899. See them HERE.
      Name:  Photo May 08, 2 50 56 PM.jpg
      You can't see the 4 slotted brackets we use on the chassis to allow the seat to be moved fore or aft by loosening & re-tightening the bolts. This does require a new rear seat support to be made, as we don't slot those typically.
      Name:  Photo May 08, 2 51 08 PM.jpg
      More build update photos ...
      NiCopp brake lines go through frame with special 2" long bulkheads.
      You can see all the triangulation & braces in the engine bay. Most folks don't realize this is where the most force & flex happens. When this area is rigid ... the tires see the FULL load of the force & create optimum grip. Any deflection is this area REDUCES tire loading & grip.
      Body bolted to the chassis just for mock up.
      If you pay close attention to the body mods, you can see how aero smooth this body is & how clean the airflow is over the roof & too the massive rear wing we'll run.
      Firewall mock up, before stepping the sheetmetal. Firewall, floor & rear bilkhead are are STEEL, for increased fire protection. We seal every seam with a special fire retardant 3M product.
      Name:  Photo Apr 30, 3 57 38 PM.jpg
      Dash mock up. (It will be capped on the ends & mount to the final X door bars once they are installed).
      Name:  Photo May 14, 3 05 12 PM.jpg
      Firewall sheet metal in place.
      Name:  Photo May 04, 11 25 11 AM.jpg
      More firewall sheet metal.
      Name:  Photo May 03, 5 11 47 PM.jpg
      Interior sheet metal showing the trans tunnel.
      Notice the U-shaped tube that the steering column mount clamps to.
      This clamp is easy to adjust to move the steering column/wheel up or down.
      Name:  Photo May 11, 5 40 53 PM.jpg
      Rear bulkhead sheet metal & rear deck sheet metal being mocked up.
      Name:  Photo May 11, 5 44 08 PM.jpg
      Different angle
      Name:  Photo May 14, 3 01 15 PM.jpg
      Basic dash before Autometer digital dash & style added.
      Name:  Photo May 14, 3 01 27 PM.jpg
      Better angle of rear deck sheet metal.
      The three tabs on the right are for the seat & harness mounts
      Name:  Photo May 14, 3 03 14 PM.jpg
    17. #37
      Nov 2012
      Sacramento, CA
      Owner: Greg Weld
      Even MORE photos of the build.
      Custom Headers & Exhaust here ...
      * The headers & compete exhaust will be coated by Jet-Hot with their 2000° thermal barrier INSIDE & out. This provides a double layer of thermal barrier to keep the exhaust heat in the exhaust, and much less heat radiating to the transmission & cockpit.
      Name:  Photo Apr 10, 5 10 18 PM.jpg
      Name:  Photo Apr 16, 1 08 12 PM.jpg
      Name:  Photo Apr 16, 1 07 39 PM.jpg
      Name:  Driver Header (4).jpg
      Name:  Passenger Header (3).jpg
      Name:  Collector & Spear Tip (1).jpg
      The headers & exhaust are a truly "Tuned" System. I utilized an exhaust flow program that allows us to input every variable about the engine, cam, etc ... and know where the "pulses" are. This system allows me to design headers with the optimum primary tube length & diameter. In this case, these are 3-step headers. With the initial tube size 1-3/4", then steps up to 1-7/8" & finally steps up to 2" before merging into 3-1/2" collectors. The program provides me with the optimum length for each step.
      In the exhaust after the collectors ... which is also 3-1/2" ... the software program allows me to put the X pipes, H-pipes, mufflers, venturi collectors and/or diffuser cones in the optimum locations. Frankly ifthese are put in the wrong location, based on where the exhaust pulses are, any of these can hurt power, instead of help it.
      * I saw a car one time with the X-over pipe in the exact wrong location. When they removed it & just ran straight tube, they picked up 45HP. That's how much power can be lost if the pulses run into each other at the wrong location.
      We use diffuser cones in the exhaust to help reduce the sound dramatically. Many tracks have db limits these days. If it placed at the right location, there is no power loss. Sometimes, even a slight power increase.
    18. #38
      Nov 2012
      Sacramento, CA
      Hey Everyone! Two Quick Announcements
      1. I'm outta here for 10 days. Going on my annual family vacation. This year we're in Yosemite with NO cell service!
      * So I won't be posting on here or answering questions until after I get back June 4th.
      2. Ron Sutton Race Technology is having a huge sale. I call this one: The Boss is Gone on Vacation Sale !
      We only hold a "SALE" twice a year. Once during the end of year Holidays ... and once RIGHT NOW - May 23 to June 1st
      * Dave Hanson & Susan Kinnicutt are Handling the Big Sale while I'm Gone.
      #1 - FREE SHIPPING on EVERYTHING in our Catalog during this sale ! Save $100's if not $1000+
      #2 - Plus - Free 2018 Ron Sutton Workshop Ticket (Regular $349) with any purchase over $1500
      #3 - RSRT Bonus Bucks to Spend on ANYTHING in our Catalog !!! (See each item for amount)
      See ALL the Sale Specials HERE.
      See Online Catalog HERE.
      If you need anything while I'm gone, contact ...
      Dave Hanson (Sales Manager)
      844-722-3832 Ext 1
      [email protected]
      Susan Kinnicutt (Office Manger)
      844-722-3832 Ext 3 (Only while I'm gone)
      [email protected]
    19. #39
      Apr 2010
      Jersey Shore
      Ron- It looks like you are using -4 for the brake lines. Is there any specific reason for this over the -3 that most of these cars used originally?
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
    20. #40
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by vette427-sbc View Post
      Hey Chris !
      No -4. We run -3 brake lines everywhere.
