      Grand Rapids, MI
      Water pump hose fitting removal
      Anyone know how to remove the heater hose fittings from an ls2 water pump? I want to tap them for AN fittings. Thanks
      65 corvette, RS chassis, LS3, TKX
      Apr 2012
      Woodstock, IL
      Apply some *even* heat to the aluminum around the fitting you want to remove and use a big pair of vise grips to work them out.
      -Dale
      SchwartzPerformance
      Grand Rapids, MI
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      Mar 2013
      Sunny Calif
      i took a 1/8 punch and gently collapsed it into itself and they pretty much fell out. loaded up my tap with bearing grease and threaded it.
