Results 1 to 15 of 15
01-23-2018 #1
Fuel pump collision safety - what are you LS guys using?
Just curious what method you guys are using to kill your fuel pumps in the event of a collision? does the GMPP computer kill the engine on loss of oil pressure? do I need to add an inertia switch? My wiring harness made it so easy to hook the fuel pump up that I feel like I am missing something here.
Cheers.Zach
01-24-2018 #2Registered User
- Dec 2010
- 709
I installed the basic Ford inertia switch that you can find in the trunk of Fox bodies and in Exploders at the junk yard. Since they fit in your pocket, all you need is a screwdriver. You can also find them on eBay for cheap. The unit is cheap insurance . . . and they work. I think it's the only Ford part on my car . . .
01-24-2018 #3Registered User
- Sep 2004
- Arizona
- 239
AC Delco
I used a ACDelco D1876D fuel pump Safety Shut-Off Switch. Check it out on Ebay. Just did it cause I Works as far as I know, I have not hit anything or rolled it over, and the motor still runs. Easy enough install for peace of mind, or just in case. https://i.ebayimg.com/images/g/838AA...Ek/s-l1600.jpg.
01-25-2018 #4
