Results 1 to 16 of 16
12-09-2017 #1Registered User
- Sep 2016
- LA - Lower Alabama
- 560
Holley 302-2 Pan hitting LS2 rod bolt
I’m mocking up my Holley 302-2 pan to check for clearances with my rotating assembly and with the pan on the block without the gasket the front rod bolt just barely hits the pan. Is this normal? I think it will clear once I add the gasket, but that’s a heck of a tight fit!!!
12-09-2017 #2Registered User- Join Date
- Sep 2004
- Arizona
- 239
Holley 302-2
When I installed mine, I rotated it by hand and the rod bolt gouged a chunk out of the pan. It looked to me, like there may have been a shift during the casting process, the dish in the bottom of the pan seemed to be in the wrong place to avoid the rod bolt. I just started grinding, and ended up smoothing out the entire inside of the pan. Just got rid of all the casting roughness, and removed more material where the rod bolt hit.
12-09-2017 #3Registered User- Join Date
- Sep 2016
- 560
Hmmm.... did it hit with the gasket installed?
It looks like it could be as little as the nut being turned in just the wrong direction. Like you’re saying, it could be just the casting roughness making the difference.
12-09-2017 #4
