Results 1 to 20 of 51
11-29-2017 #1
Project "ANVIL" F100. Built to be beat on
Hey all
I’m pretty virgin (be gentle) to this whole Pro-touring / handling thing so this Is a learning curve for me.
Quick back story on the toy, I bought this truck 5-6 years ago from the original owner with the sole intention to just drive the wheels off of it. it’s a 1967 Ford F100, short bed, 240 6 cylinder, 3 on the tree. I did start driving it and honestly loved it. tons of complements everywhere I went. One morning I went out to leave for work and the truck was in the middle of the street. at this point I knew the engine was done. Virtually zero compression and just plain worn out. So being that I work in the performance world and I like to do things a little different I decided that I need to build a 300 6 cyl…..so I did… block was zero decked, flat tops, ported head, nasty custom ground cam, header with twice pipes and a 600 cfm 4 barrel, and a Frankenstein electronic ignition that I built. I installed the engine, broke in the cam and took her for a test drive. Thing was fun to drive. Skinny little tires just spun their butt off. After the test drive I never touched the truck again. Life was just crazy, 2 athletic boys in high school that did sports year round took my attention from the truck….all good. My boys are my life……………..BUT now that they are graduated and off to college …………….. IT”S MY TURN !!
Here is the NEW plan (with heavy influence from the Hackster built)
THIS IS A VERY BUDGET ORIENTED BUILD. NOTHING CRAZY HIGH END AND 100% DONE BY ME
2009 cop car (p71) Crown Vic front swap, Lincoln Mark VIII IRS rear, coil over’s all 4 corner’s, 3:55 gears and a posi, 2016 Mustang track pak wheels tires, stick with the 6 Cyl for now, T-5 5 speed for better gear split and over drive. Future plans are swapping to an 6.0 LS, Mast head’s, custom cam, Holley Hi-ram, 102mm t-body. 120 injectors, along with an S480 turbo that is in my garage now. I’m looking for a T-56 6 speed but I have a TH400 in the garage and might just go 4L80E……….anyways
Here we go
- - - Updated - - -
Can't seem to add pics
