      Fidanza 13lb flywheel and Spec stage 3 clutch
      I have a Fidanza 13lb flywheel for sbc with 2 piece rear main seal, with a Spec stage 3 or +3 clutch assembly 26 spline for tko600. This set has been properly seated with 836 miles on them. I have gone a different route with my setup and am needing to get rid of this one. Everything operated flawlessly and the engine reved very quick with such a light weight flywheel, made the car a blast to drive. I have quite a bit invested in this and am asking $500 obob plus shipping. I used a mcleod release bearing with my setup so I am including a new standard release bearing with it. Please ask any questions you may have. This was used in 68 camaro 385 w/ tko600 and 4.10 rear gears.
      1968 Camaro Crossram EFI 385, TKO 600 fully REMed. 594 hp/576 tq-ft. ATX spindles, Speedtech control arms, Chassis Works G-Link on 12 bolt with REMed gears, Chassis Works mini tubs, 245/40-17 front, 335/35-17 rear.
      Pictures
      Sep 2007
      Montgomery, Tx
      Where are you located?
      Gary Rys
      69 Camaro
      Sophia, nc
      Fidanza Flywheel http://www.jegs.com/i/Fidanza/383/198681/10002/-1
      Spec Clutch http://www.specclutches.com/695164/
      Open to any offers, I need this set gone
      Bump
      Still available. Make offer
