Results 1 to 20 of 45
10-16-2017 #1Registered User
- Jun 2017
- 32
65 GMC Short Fleet, Pro Touring Big Block Build
As the owner of a 65 GMC it did not take much to get my best friend to jump in with both feet to build one of his own.
We have a nice big shop here in the back of my building that we set up to build this truck in.
We even built our very own fabrication fixture to build on.
Plans go like this;
Rob @ No Limit sold us a wide ride front end, A raised rail rear kit, a Moser 9 rear end narrowed 8" his fat bar 4 link kit and of course Willwoods stoppers for all corners.
So I will just post a bunch of pictures to date. we have been on this build since Sept. 1
here is the stock frame loading on to the fixture.
10-16-2017 #2Registered User- Join Date
- Jun 2017
- 32
10-16-2017 #3Registered User- Join Date
- Jun 2017
- 32
once the stock frame and fixture were married it was time to cut the back off and make room for the No Limit raised rear rail set up
10-16-2017 #4Registered User- Join Date
- Jun 2017
- 32
the raised rear rail kit that Rob built is a dream to work with. I could not be more impressed both as a builder and as a fabricator.
I boxed it all in and welded in all the cross members to insure rigidity and strength
Once that was complete I welded on the forward 4 bar mounts.
Then we went ahead and got the rear end in and welded on the Panhard bar mount and shock mounts, then hung that beautiful Moser housing.
10-16-2017 #5Registered User- Join Date
- Jun 2017
- 32
The "Wide Ride" from No Limit is an impressive piece of kit. Simple as heck to get into position and built like it was designed for the Space Shuttle.
We had this on and adjusted including removing the stock front end in under 2 hours.
10-16-2017 #6Registered User- Join Date
- Jun 2017
- 32
That is pretty much to date. The frame is boxed and we have the body sand blasted, will be installing tons of new sheet metal in it as well as a sweet paint job.
This truck is powered by a 454 hooked up to a kitted 700 R4
Will continue to update as we get deeper into this build. Only have weekends and after work to get anything done but we are motivated and we have a nice shop to get this one done in.
10-16-2017 #7Registered User- Join Date
- Sep 2011
- Southern Ontario
- 640
