    Results 1 to 17 of 17
      Oct 2014
      DFW, Texas
      T56 Magnum Shifter Rattle - Only under high torque, not speed-related w/video
      I am looking for some input on a pretty new T56 magnum install I have, and some ideas to move forward and find this issue.
      • The install has about 700 miles on it
      • I have no driveline vibrations under light loads, in any gear, up to 80-90mph (which is how high I have safely tested it)
      • My problem seems to be only under heavy load.
      • My engine is tied down with a torque strap and has no rotational movement
      • Trans may be hitting the tunnel somewhere I can't quite see
      • Shifter handle is directly bolted to the trans shifter nub, no isolation
      Ideas moving forward
      • Further investigate areas that may be hitting the tunnel, try to clearance, if necessary
      • Remove torque strap and drive
        • My header will likely hit on something else, but it could tell me something
      • GoPro the axle pinion
        • It may be wrapping up hard enough to throw my driveline angles off, but that would get substantially worse in every gear as the driveshaft speed increased. Which it is not doing.
      The video shows a steady cruise and as soon as I hit the throttle, you can hear the rattle start to ramp up with rpm. It will do this in 2nd, 3rd, 4th, etc. at a similar magnitude. If it was a drive
      Video: <a data-cke-saved-href="https://youtu.be/6w918yL8IrM" href="https://youtu.be/6w918yL8IrM">
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      I've got 3 of them installed, and all rattle except one with an upright shifter arm. I think it's the shifter itself rattling, and it's made worse by leverage of a long curved shifter arm. The Lightning after-market shifter rattles less, but tends to leak.
      The rattle is in the connection between the ball end of the shifter and the shifter rail.
      John Parsons
      Wow...that rattle would drive me insane!!!
      Instagram @projectgattago
      Dr. EFI
      Oct 2014
      DFW, Texas
      Well I am glad to hear that I am not alone, but I am not so glad to hear it's internal.
      Have you found any cure for the connection at the shifter rail? I have thought about modifying my shifter to be more like an OEM application. The Tremec T5 that came in the Fox body mustang seems like it could be adapted, it's pretty heavily isolated from the trans.
      Name:  T5 mustang shifter.jpg
      Beach Park IL
      This. Isolating the stick from the stub shouldn't make a bit of difference.
      You do have the plastic bushing in there, right?
      Donny
      Oct 2014
      DFW, Texas
      No idea, I've never had the shifter off. I filled it and put it in just as SST sent it to me.
      I would think reducing the shifter handle's ability to be a megaphone would help at least reduce the amount of noise it makes.
      Heavy grease will quiet it for a bit, but it always comes back. My customers have gotten used to it, but I hate it. I wonder if powder coating the ball or some other "build-up" process would help? I've got one of the rattlers back in now for some maintenance, maybe I'll have another look.
      John Parsons
      Beach Park IL
      So it's an SST shifter? I assumed it was a Tremec shifter, the red one.
      Donny
      Oct 2014
      DFW, Texas
      I hate it as well, especially for a $3,000 brand new trans. If I didn't have to pull the trans to get to it, I'd grease it, but that seems like a lot of work for a short term fix. I'll put another 200 miles on it next week.
      I do have a pretty good amount of slop in the shifter.
      It's the Tremec red shifter, I don't think SST changed anything there.
      Sep 2009
      Ontario, Canada
      Are replacement bushings and pivot pins available for the stock Tremec Magnum shifter - not the one for the ball to the rail, but the fore-aft and side-to-side bushings and pins of the pivot link? Fore-aft guide pins are basically turned-down bolts screwed in from either side and engage bushings in the link. Side-to-side pivot pin is pressed into the stub through the bushings in the link. The bushing to pin clearance seems excessive on mine contributing to sloppy feel and rattle.
      Thanks for the help!
      Feb 2011
      dallas, tx
      You sure the shifter bolts are tight? Where are you located in dfw? I'm in allen and we can use my go pro to track it down
      Oct 2014
      DFW, Texas
      Quote Originally Posted by AMC Racer View Post
      I am not sure what replacement parts are out there, but mine has done this since I first hit the throttle decently, ~100miles on the car/trans.
      Quote Originally Posted by icemanrd19 View Post
      Yes, the bolts are tight. Thanks for the offer, I have borrowed a GoPro to test it out with. Hopefully this weekend if the rain isn't too bad. SST has asked if the noise goes away without the shifter handle, I will test that as well.
      Oct 2014
      DFW, Texas
      Just an FYI for anyone else looking into this problem or acquiring a T56 Magnum. Tremec's response to my inquiry is below:
      The noise you are experiencing is a rattle in the connection between the ball end of the shifter and the shifter rail. This is normal and not warrantable. This noise will typically get worse the further the shift ball is from the fulcrum point. In your 72 Cuda, I am assuming the lever is relatively long and swept back with a pistol grip on it, this is the worst combination for this rattle. Unfortunately, we do not have any isolator solutions.
      Dec 2011
      new york
      Quote Originally Posted by GoodysGotaCuda View Post
      That is a ridiculous reply. Thanks for the $3000+ but we don't care that you are having an issue.
      Oct 2014
      DFW, Texas
      Quote Originally Posted by 1985olds View Post
      I'm disappointed to say the least. I asked about potential solutions or methods to mitigate it.
      The OE’s use isolators and remote mount shifters to minimize the noise. Unfortunately, we do not offer any isolator solutions.
      Basically, tough bananas. You're on your own.
      What annoys me is that they sell a "hot rod" transmission where nearly 100% of the installations will be like this case, a relatively long shaft with a pistol grip, or a ball. There is a known issue and they have no solution for the end user. This is not a brand new transmission offering that doesn't have the bugs worked out of it yet, it should be fixed.
      I suppose I am relieved to know that the transmission isn't destroying itself, but for $3,000+ and 1,700 miles on it, I'm not happy.
      Feb 2008
      saint clair shores, michigan
      I know this is older but having the same problem with my t56. What did you end up doing for a solution?
      Jul 2008
      To also reply to this older thread, a lot of "performance" t56's get a bronze bushing in the isolator cup for the shifter ball:
      https://www.tickperformance.com/tick...ions-part-95b/
      This would cause any noise generated by the trans to travel up the stick. Factory uses a plastic cup to help isolate the noise, you could get one of these, pull the shifter, and replace the bushing w/ this plastic cup.
      https://www.amazon.com/AMP-Transmiss...C1PN31WAR3G07E
      Factory is plastic bushing, they wear over time but help isolate the shifter.
      *Jeff*
