Results 21 to 30 of 30
10-03-2017 #21
Donny, We will have to agree to disagree I believe on some of this.
As far as adjusting air pressure to turn the car, it is not the "right" way to do it. But, when you are at a race and that is all that is left that can be changed I will take corner speed over maximum acceleration every time.
On the sway bars. That one has been argued out plenty of times already, IE soft springs & heavy bars or heavy springs & soft bars. Pick your poison, lots of fast cars out there with each setup. For track cars I like heavy springs for street cars I typically use softer springs with heavier bars.
OP, I agree with Donny. You need to drive the car more and maybe have someone more experienced make a couple laps and give some insight.
There are lots of variables that can be manipulated to get a car to run fast. Most guys though are not going to go changing pick-up points, track widths or even get a square tire setup. This leaves us for the most part with tires, springs, bars, shock/springs & alignment. I have been fortunate enough to get to drive quite a few cars for different owners. I have driven cars that handle fantastic and then got into one that felt like it was just going to roll over. Lap times were barely different. If you can get the car balanced you can make it go fast with seat time.
10-03-2017 #22Registered User
- Feb 2011
- dallas, tx
- 1,730
