      Jul 2016
      trunk mounted battery question on GM purple wire
      To the guys who installed your battery in the trunk... Did you use a Ford type solenoid as well ?? If yes, Did you connect the purple wire from the ignition switch AND a new wire from the Ford type solenoid to the "S" terminal on the starter ?? In simple terms, do you have 2 wires on the "S" terminal of the starter ???
      Dec 2008
      Detroit
      The purple ignition wire goes to the Ford solenoid. You will need to make a small jumper wire on the starter from the battery terminal to the start terminal
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Bowler Performance, Rushforth Wheels, ATS, Holley EFI, KORE3, Ridetech
      Project Motor City Madness
      Jul 2016
      Thank you for the reply. NO jumper wire for an LS swap. The jumper wire causes "Run On".
      Dec 2008
      Detroit
      It doesn't on mine
      Chris--
      Dec 2008
      Detroit
      Quote Originally Posted by DT69Cam View Post
      As in the starter remains engaged after you release the key? Mine has a jumper and when I let the key go the starter stops spinning....
      Chris--
      Texas
      Some people apparently have experienced run-on presumably because when using a magnetic type starter the starter cranking can induce voltage through the jumper wire after key is off and starter is still spinning for a brief amount of time. I don't think it is limited to LS platforms unless they predominately use mag starters? There have been posts re this before but I didn't go looking for them. Mine is wired as OP has his. If no run-on use the jumper.
      -Bob (66 Nova)
      Dec 2008
      Detroit
      Quote Originally Posted by BBPanel View Post
      Thanks for the insight ....
      Chris--
      Jul 2016
      Quote Originally Posted by csouth View Post
      Yes.
