      Sep 2017
      1966 Biscayne power disc brake conversion
      I have a 1966 biscayne with a 427/4 speed. No power brakes or power steering. The steering is not too bad for now but these drum brakes have got to go (on the front at least)
      What bolt on kits do you guys recommend?
      The car has 15" wheels btw
      Jeff
      tx
      Quote Originally Posted by jeff198901 View Post
      Jeff
      Jeff,
      did you do a conversion yet ? just wondering what you came up with.
      66 Impala
      86 Corvette
      85 C20
      77 Cordoba
      Jun 2006
      Katy,TX
      Scarebird as an Impala kit. Also second gen Corvette front spindles and brakes bolt to Impalas also and had 15" wheels.
      1965 GTO project car
      2004 Pulse Red GTO
      tx
      Wilwood 140-12022 front brake kit
      I ended up going with a Wilwood front disk brake kit that uses your stock drum brake spindles. This is an outstanding kit. All the parts in the kit are very high quality. The kit has 12.19" rotors with fixed 4 piston calipers.
      66 Impala
      86 Corvette
      85 C20
      77 Cordoba
