      Apr 2011
      67 Camaro ZZ502 TKO600
      Price: Sold
      1967 Camaro RS/SS tribute car. This Camaro started life as a base model,this is a solid rust free body, all panels are original GM. Everything works, handles like it's on rails and drives like a dream.
      The engine is a GM crate ZZ502 (GM part number 12496962). 502 cubic inch big block Chevy with aluminum heads that is factory rated at 502 horsepower and 560 ft/lbs of torque. Jet hot coated Hooker headers and 3" Flowmaster exhaust. The transmission is a Tremec TKO600 5 speed that is rated to 600 lbs of torque with a Hurst shifter. Out back is 12 bolt posi with 3.31 gears. Brand new 18' billet rally wheels, 18x9 in the rear with 275/40-18 and 18x8 in the front with 245/40-18 tires.
      4 wheel disc brakes, the front are GM factory disc brakes with 4 piston calipers and the rears are from Master Power brakes with an 8" power booster. All the brake lines are stainless steel with braided stainless lines to the front calipers. All the front suspension was replaced with new parts, including and a fast ratio (12.7 to 1) steering box, coil springs, 1" sway bar all from Guldstrand Engineering. The underside has been bead blasted and painted, the front sub frame was epoxy coated.
      Options added to the car include full RS package with working electric hide away lights, fold down rear seat, tilt column, deluxe interior and rear defroster, center console and restored factory AM/FM radio. The car has approximately 8,000 miles on the restoration and drive train. It starts every time, runs excellent, the clutch and transmission work flawlessly. Please note I am not representing this car as an original RS/SS, it's a tribute, clone, better than the original recreation or whatever you want to call it.
      Factory added options include:
      Rosewood steering wheel included with sale (Grant GT steering wheel currently on vehicle)
      Tilt steering column
      Rear window defogger
      AM/FM Radio
      Deluxe interior
      Fold down rear seat
      Center Console
      Power Steering
      Super Sport Hood
      Hide away headlights
      Modifications and Upgrades:
      1" Guldstrand Front Sway Bar
      Four core radiator
      ZZ502/ 502 GM Crate Engine
      Tremec TKO 5 Speed Transmission
      Hurst Shifter
      Guldstrand Heavy Duty Front Coil Springs
      Polyurethane bushings throughout
      CenterForce Dual Friction Clutch
      LakeWood Bell Housing
      Competition Engineering Sub-Frame Connectors
      Aeromotive fuel pump
      Eldebrock High Flow Aluminum Water Pump
      Dual Electric Fans
      AutoMeter Ultra Light Gauges- Speedometer, Tachometer, Gas, Oil Pressure, Water Temperature, Air Fuel Ratio, and Shift Light.
      Hooker Competition Headers with Silver Jet Hot Coating
      Master Power Rear Disk Brakes
      MSD 6AL
      3" FlowMaster Exhaust with Crossover
      optima Gel battery Relocated to the Trunk with Taylor Aluminum Box
      GuldStrand Fast Ratio Power Steering Box 12.7 to 1
      Milodon 8Quart Oil Pan
      Walk around video https://youtu.be/hP0ilc408EU
      Untitled by Kill Bill S, on Flickr
      Aug 2005
      Hamilton, NJ
      I love this car. Glws
      Scott from NJ.
      Vent Windows Forever! ...
