09-03-2017 #1
S10 master port location, Hydraboost, Distr block.
I have fitted the hydraboost and turned down the neck on the mid -80s S10 master to fit.
- Is there another GM master (non angle location) 24mm/ 15/16" with the ports on the inside? This will make the plumbing easier. 24 & 31.75MM CYL BORE MC P/N: GM 18030555, or Delco 18M313 Will this fit ?
- Can I use the distribution block with warning light from a -68 Nova ? Then I will maintain the function of the light. ( I will add the adjustable proportion valve on the rear line.)
