    Results 1 to 20 of 29
      Eastern Virginia
      I'm done, I'm done, I'm done, with Optima batteres
      They suck any more, been through 3 in the last 4 years. They used to be great, I used them in everything. But if you don't drive it every day they seem to fail.
      What are you using?
      Scot
      86 Monte SS
      May 2008
      Chicago
      I us a battery tender on it and I have had them last 5 years plus.
      Quote Originally Posted by Samckitt View Post
      What are you using?
      3 in 4 years - they have a 3 Year Warranty!
      at Hot August Nights, I was next to the optima Rep - one thing he kept telling people was they needed a "Smart" Charger. Most Chargers are giving a battery a full shot (say 12 amps) when they might only need 4 amps.
      May 2013
      Colton Ca.
      I use a simple Interstate battery from costco.... $90 bucks,no hassle Warranty and starts every time (and I leave cars sitting months on end) . I got tired of all the expensive Battery failures to.
      Ahmad B.
      Mountain Springs, Texas
      I use Odyssey. A little expensive but they do fine when the car sits for long periods.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2013
      Gilbert, AZ
      Don
      They are a bit pricey, but the cost of an optima is steadily creeping up towards the cost of the Odyssey! Thinking I might try one out, I like that they are a true dry cell.
      Dec 2010
      Peoria, AZ
      Quote Originally Posted by CampbellshotrodsAZ View Post
      I ran a small Odyssey in my 92 for years. Expensive but it worked if I started the car somewhat regularly. I imagine a full size one would perform much better than the half size one I used.
      Tom Pichette
      Pit crew for Valerie Pichette and her 1988 Pontiac TransAm GTA "DragonLady"
      Jul 2013
      Gilbert, AZ
      Quote Originally Posted by Project92rs View Post
      That's the other thing I wonder. If by going to a smaller battery, I save $ and some weight. I need to do some figuring and try and guess what might work. I'll be relocating 2 batteries to the rears of cars soon... the 71 Firebird and the 82 Z.
      Jul 2015
      Jun 2014
      Quote Originally Posted by krom View Post
      If you're leaving your car sitting around when you have a AGM (Absorbent Glass Mat) battery, which is what optima, Odyssey, XS Power etc. are. You NEED a smart charger / float charger / Battery Tender, whatever you feel like calling them that's made to handle AGM batteries not just a regular car charger like mentioned before.
      The smart chargers do a good job at charging the batteries and also have a float mode when it reaches full charge that lowers voltage avoiding overcharging the battery. If you don't have a charger on a AGM battery the voltage can drop too low per cell, usually making them un-salvageable. optima has it's fancy new charger that says it can recover a heavily discharged AGM battery. The normal AGM smart chargers aren't huge money and just hook it up and leave it for as long as you need to...Easy insurance really.
      If you're leaving your car for months at a time...get one!
      Last edited by Jerems; 09-29-2017 at 10:28 PM. Reason: Removed wrong pricing info.
      Aug 2012
      Peoria, AZ
      Or... Just don't leave your car sit for long periods of time. :D
      I used the cheater method of charging to revive my red top over 6 years ago when it was too dead for a normal charger to charge it...and it's been going strong ever since.
      Lance
      Beach Park IL
      I have posted this before, I have saved "junk" red tops by hooking jumper cables from the optima to a regular battery and then charging.
      Donny
      Aug 2015
      NJ
      I just bought a Braille battery for my big block. So far soo good.
      Jan 2013
      Cypress, California
      I had an optima but a cell went bad within a year and it could not be revived. I now have a Sears Diehard and it is working just fine.
      Eastern Virginia
      I tried that with last one with no luck. I ordered the optima battery charger/tinder, maybe it will bring this one back.
      Scot
      86 Monte SS
      Milwaukee, WI USA
      I use the Farm & Fleet branded batteries made by Johnson Controls.
      They're just the simple old style batteries that will last 7 years or more.
      No complaints here.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      Feb 2011
      AC Delco in everything.
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Quote Originally Posted by 77thor View Post
      No complaints here.
      Optimas are made by Johnson Controls in Mexico
      There are only a few battery companies that market Batteries under Hundreds of names
      Chicago suburbs
      I also use Braille, B3121. Have for years now. It is about the size of my lawn tractor battery, and people always comment on that. So small that I won't bother putting it in the trunk. I use a Ctek charger, which works great.
      Eastern Virginia
      The optima 400 battery charger showed up today at around 4pm, it is now 9:30pm & it says battery is at 75%. Should it take that long, or is battery toast?
      Scot
      86 Monte SS
