    Results 1 to 14 of 14
      Nov 2012
      Sacramento, CA
      New 400 Page RSRT Catalog / 10 New Product Lines & 3000 New Products
      Today is THE Day! Launch Time!
      • 10 New Product Lines
      • 3000 New Products
      • 3 Years in Development
      New Catalog:
      • It’s Big! … 400 Pages Big !
      • It’s Full of Go Fast Cars, Parts & Kits
      • From Chassis, Suspension & Brakes ... to Engines, Drivetrain, Aero & More
      • It is Your One Stop, Turn & Go Fast, Car Building Resource Center
      • For Autocross, Track Cars, Road Racing & Triple Duty Pro-Touring Cars
      3 New Product Lines for Ford & GM Muscle Cars:
      • AutoX-Star Packages
      • AutoX-Warrior Packages
      • Track-Star Packages
      Track-Warrior Cars:
      • 4 Levels: From the Base Model TT … to TA2 & TA … and the Top of the line GT
      • 4 Ways: Turn-Key Track Car / Rolling Chassis You Finish / BYO Kits / Part by Part
      Suspension Packages:
      • 4 Levels of Front Frame Clips with Suspension & Steering / Custom Built for Your Car
      • 4 Levels of 3-Link Rear Suspensions with, or without, frame rails & rear ends
      • Including 2 Levels of our Infamous Race Dominating Decoupled 3-Links
      • Torque Arm Rear Suspension Packages with, or without, frame rails & rear ends
      • Quik-Tune Shock Mounts in 18 Versions
      • Double Adjustable Quik-Tune Panhard Bar Kits – 6 Versions
      • The Ultimate Quik-Tune Watts Link Package – 3 Welded Versions & 2 BYO Versions
      StopTech Triple Duty Brakes:
      • Designed & Optimized by Ron Sutton to be the Best Brake System for Street, Autocross & Track
      • Amazingly utilizes only 1 Pad for Street, Autocross & Track
      • Front Applications: GM A, F & X Bodies, C5/C6, Speedtech, ridetech, DSE & RSRT
      • Rear Applications with Parking Brake: 9” Ford, 10/12 Bolt GM & Speedway Floaters
      • More Applications Coming by End of Year
      Warrior Engines by Ron Sutton & SDPC RaceShop:
      • 12 Powerful LS Engine Packages
      • From 550 to 900 HP – Naturally Aspirated !
      • Wet Sump & Dry Sump Oiling Systems
      • Most Linear Power Curve Available on the Market
      • Built Better, Stronger & More Durable with Higher Grade Parts
      • Plus Scott Clark Pre-Programmed ECUs & the Best Accessory Drive Systems
      Wide Range of Engine Accessories to Complete Your Powertrain:
      • Holley HP & Dominator EFI ECUs & Harnesses
      • Drive Junky - The Best LS Accessory Drive Systems / With or Without AC / 3 Finishes
      • Holley & Canton Road Race Wet Sump Oil Systems & Accusumps
      • ARE Dry Sumps Systems for All LS Engines
      • Motor Mounts & Adapters / Motor & Mid Plates
      • Bolt On Headers & Build-your-Own Header Components
      Drivetrain Products to Complete Your Mean Machine:
      • Blueprinted T56 Magnum 6-Speeds & Sequential Shift 6-Speeds in 3 Ratios
      • Complete Ford 9” 3rd Members / 4 Differential Options / 7 Gear Ratios
      • Detroit Lockers & Tuning Springs / Ring & Pinions & Install Kits
      • 4 Levels of Clutches / LS Bellhousings / 3 Levels of Custom Driveshafts
      Cooling & Plumbing:
      • Radiators from Basic to Advanced with Built in Coolers & Fans
      • 19 Coolers for Engine Oil, Power Steering, Trans & Rear End Coolers
      • Every Overflow, Vent Tank & Accessory Needed
      • A full 22 Pages of Plumbing Hose, Hard Lines & Fittings
      Cutting Edge New Products:
      • AutoX-Star Control Arms for Muscle Cars – Higher Caster & Motion Ratio
      • Billet Steel, Slugged Centerlinks for Optimum Bump Steer
      • Shock Rocker Arms for Pushrod, Pullrod or Rocker Arm Suspensions
      • Trick New Coil-Over Shock & Spring Accessories
      • New … and I mean NEW … Power Steering Pump with Tunable Flow Rates
      Public Release of Trick Products:
      • Billet Steel 3-Link Top Link Adjuster & Extension Rod Kit
      • 3-Piece Sway Bar Kits / Front & Rear / Easy to Weld In
      • Ron Sutton Configured Full Containment Race Seats at Only $899
      • Low CG Fuel Cells for Street & Track with All the Features
      • Custom Made Splitters & Advanced Downforce Wings – 15 Versions
      Stuff to Build-Your-Own Stuff:
      • New Laser Cut Rear Frame Rails & Crossmembers with Special Features
      • Every Trick Part & Piece We Use – Available to You the DIY Car Builder & Pro Shops
      • Every Bracket, Tab, Slug & Mount You Need
      • Trick New Bay Bar Spuds & Roll Cage Dimple Die Gussets
      • Our Powder Coated, TIG Welded 1.25” OD Suspension Tubes in DOM & 4130
      • Everything you need to build your own car from Sheetmetal to Plumbing
      Tools-Tools-Tools:
      • The Trick Tools to help You “Build-Your-Own” AutoX or Track Car
      • The Best Tools to Setup Your Car Before Events
      • The Optimum Track Tools to Know “What’s Up” & Dial In Your Car at the Track
      Ron Sutton Tech Services:
      • Services Where Ron Works Direct with You on Your Car Project
      • Suspension Tech Services to Optimize Your Production Car
      • Chassis Design Services to Build the Mean Car of Your Dreams
      • Plus Calculation Services to Optimize Your Brakes, Gearing, Powertrain, Aero & More
      Ron Sutton Secret Sauce Valved Shocks:
      • ridetech Single & Triple Adjustable / 2.9” Stroke to 6.9” Stroke
      • JRI Triple Adjustable / 4” Stroke to 7” Stroke
      • AutoX-Star, Track-Star & Race-Star Valving / Front & Rear Specific
      • Plus – The Full Line of Draco 9000 Series Quick Response Coil-Over Springs
      Lower Prices on Key Items:
      • RSRT Awesome GT Spindles & GTR Rear Steer Spindles – Now Only $799
      • Roll Cage Packages / 4 Versions / All Cars / Starting at only $799
      • HANS III devices in 4 Versions / Only $549
      • Forgeline Wheels / All Versions / Special Pricing
      Dealer Listings:
      • Work with RSRT Direct or One of Our Authorized Dealers
      • Ron Works on Your Project with Your Chosen Dealer / Same Great Tech Support
      • Find an Authorized AutoX-Warrior Installer near You
      • Pick the Best Authorized Track-Warrior Builder for You to Work With
      That’s all.
      Just 400 Pages of Most Complete & Comprehensive Line of Products & Services to Assist You in Building Your Ultimate Autocross, Track Car, Road Racer or Triple Duty Pro-Touring Car.
      – Ron Sutton
      See it ALL in our New 400 Page Catalog HERE!
      Name:  2018 Catalog Front Cover.jpg
      Aug 2012
      Peoria, AZ
      Hey Ron, on page 182...which ones do I need?
      Love this catalog BTW...can I get a hard copy of one?
      Lance
      Lance
      Jul 2013
      Gilbert, AZ
      Curious on this as well. SEMA workshop perhaps? I'm more old school in that I like flipping through paper more than webpages.
      Nov 2012
      Sacramento, CA
      Lance
      On Page 183, RST # 7750-A & 7750-B have already shipped to you.
      YES ! We will have hard copies of the catalog. Actually, we already had hard copies in a slightly shorter version of "only" 348 pages that we distributed at two race events. They're all gone. The next printing round is the 412 page version. Should be to us in 2-3 weeks.
      - - - Updated - - -
      Quote Originally Posted by CampbellshotrodsAZ View Post
      Yup, I'll have one for you at SEMA, unless I see you at the USCA/optima event in Fontana!
      Oct 2007
      Camas, WA
      Great catalog Ron! I would also like to pick one up from you at SEMA. Thanks for being such a great information source for parts and more importantly tech!
      I hope to have more updates on my Volvo build thread soon to show off your suspension. My install guy is swamped with race season and now some personal things.
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by 68EFIvert View Post
      Thanks Darreld !
      Be sure & post photos once your shop starts installing the new RSRT TA2 clip & stuff.
      corona,ca.
      Ron,can i get one of the catalogs at fontans?i'll be there sat.
      Phil
      72 chevelle.
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by chevelletiger View Post
      Phil
      Yes sir. 412 full color pages go fast car goodies. LOL
      corona,ca.
      Ron,it was nice talking with you on sat.at fontana.
      Thank you for the catalog.
      Those new a arms are pretty sweet.
      When are you posting some pics here for the other guys to see,that didnt get to see them at optima this weekend.
      Those and the upper mount are on my TO GET LIST!
      Phil
      72 chevelle.
      Nov 2012
      Sacramento, CA
      Phil
      Great to see you Phil. Man was it hot last weekend!
      I'll be posting a lot of our 3000 new products over time. I'll make the new high motion ratio/high caster control arms & shocks mounts first.
      Take care !
      Nov 2012
      Sacramento, CA
      1 Ticket Left for Texas Workshop
      We moved the location of the Texas Workshop to "The Speedway Club" at the Texas Motor Speedway. This allowed us to increase the size of the table layout & available chairs.
      We're almost sold out. 1 Ticket left.
      You can join all your buddies & learn a lot too. This Thursday, Sept 28th (8am to 5:30pm) the day before the Good Guys event starts.
      Get your ticket HERE.
      Sep 2008
      Jacksonville, Florida
      Did you ever get the bearing spacers for your front hubs made? Couldn't find them in the catalog.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by sccacuda View Post
      Craig, didn't I email you or text you an answer on this? If not, the answer is the hub bearing spacers are on our list of more new products to come out with, but it's pretty far down the list. They're a cool little friction reducer, but not required by any means. So they're a low priority right now. The catalog shows over 3000 new products we've launched. There are about 125+/- more new products on the future list.
      Nov 2012
      Sacramento, CA
      Listen to the optima Podcast #56
      Robert Kibbe & I talk about our new catalog, AutoX-Star, AutoX-Warrior & Track-Star Suspension packages.
      Go HERE.
      Then check out the AutoX-Star, AutoX-Warrior & Track-Star Suspension packages in our new 412 page monster catalog HERE.
