    Results 1 to 15 of 15
      Dec 2014
      Murfreesboro, Tennessee
      Hot start issue...FiTech
      Got the valve covers apart and trying to figure out no start hot starts. Rockers are loose on some of the valves. Could this cause a no start condition when hot? Thanks in advance
      1971 Firebird Formula 455HO 6 speed
      2017 GMC Sierra Denali Ultimate Pearl White 6.2L
      2013 GMC Sierra 5.3 6 Speed Pearl White, SLP 1.9L Supercharger(Sold)
      Quote Originally Posted by 71LS5Formula View Post
      Sure would help to know more about what engine you're working on...Carb? EFI? Details...
      Dec 2014
      Sorry. Pontiac 455HO. Roller cam. Runs about 12"of vacuum. Fitech efi. HEI ignition. Vacuum advance not hooked up at the moment.
      I suppose loose rockers can cause this, but my money is on the Fitech. I would fiddle around with the start-up settings. The combination of cranking pulse width and IAC position is effectively your starting AFR...
      Dec 2014
      I'll check all that out. Thanks for the advice. This posting can be moved to the efi section for further advice. Thank you.
      Feb 2011
      dallas, tx
      fuel pump get loud after trying to hot start it? Buddies did and eventually the system learned itself and hasnt happened again. How long have you had the Fi tech setup?
      Dec 2014
      I've had it about 2 weeks run time. I figured it would be valves not properly adjusted or the ignition control module as it seems to flood out while hot.
      Jan 2010
      Sunset, Texas
      There is a Fitech owners Facebook page that could be very helpful answering questions. I suggest you join the group and do a search on your problem.
      Dec 2014
      I was looking at a page on fitechs website talking about the IAC steps. Says they're supposed to be between 3-10 steps. Looked at them last night real quick and mine are up at 225. Gonna do some more troubleshooting hopefully after i get homme today.
      Dec 2014
      Well. The efi is putting so much fuel in the throttle body it's actually filling it up. Now it's the fun part. Trying to get a hold of fitech.
      Jun 2013
      West Blocton, Al
      If the injectors are continuously dumping fuel when you turn the key (before you crank) its getting a noisy tach signal ( for some reason it wont do this if you reset the system on the first start up but every time after it will flood the motor)
      . Check the RPMs on the handheld to make sure it doesn't think its running before you crank it. I had an issue with the wire 12 volt source for the distributor being wired on the wrong post on the starter (SBC). swap the wire to the other post rpms cleaned up and just got a prime shot. Another trick I use if the car is hot is to allow the fuel command center to reach pressure and turn off before I crank the engine.
      also do get the IAC steps corrected this also is an important step.
      Hope this helps
      Dec 2014
      Quote Originally Posted by silo84 View Post
      Hope this helps
      Tach signal is good and clean. I'm not running a command center. Intank pump setup. It fills the throttle body while cold.
      Dec 2014
      Keyed the car on tonight and noticed that only the rear two throttle body ports are filling. I did a reset to factory tune and started over. Set my parameters. Keyed it back on and the rear filled up again.
      Oct 2007
      Georgetown/Austin, TX
      Hey, just curious if you found out what was going on. Any luck getting it fixed?
      Dec 2014
      Had to send it back to fitech.
