06-03-2017 #1Registered User
- Jun 2017
- 1
Procharger pulley to boost ratios
Hey, I noticed that there wasn't a comprehensive list
Of pulley to boost ratios for the Procharger units.
I am going to start one. If you have any info based on your engine. Send me info.
I have a 2002 Jeep 3.7L V6 custom built with 9.8:1 ceramic top pistons, Internally balanced crank with an additional balance shaft, ATI 6" crank pulley, ported/polished, /balanced port heads, oversized AS valves, S.O.S coil packs, Brisk spark plugs, Fastman throttle body.
We will dyno the engine in the 500 horsepower range. Shift rpm is 6500.
We are building this motor for endurance racing off road. Any idea on what Pulley size to get 10 lbs. Boost
