      Denton Texas
      neutral safety switch help... I know how to set up looking for a switch
      Hey guys, Im wanting to run a non GM, plastic stick Neutral Safety switch...I found a switch I thought would work here in the pics, the problem is its the opposite of what I need push down is off and not engaged is on(car starts).. Im running a 6 speed, I have the B&M micro dont like it.. what option do you guys use??
      Kevin
      Beach Park IL
      Use another brake light switch.....and a relay.
      Donny
      Mountain Springs, Texas
      I have used the Lokar switch with good results but you will need to figure out where to mount it and make a bracket since it is more of a wipe activation than a push like the one you showed.
      I've got one here that I can let you try to see if it will work for you.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Ontario, Canada
      I used a sealed momentary contact switch as a reverse light switch on my Hurst 4 spd. shifter. I would think something similar should work for your neutral safety switch. There are lots of choices out there.
      Ken
      My other car is a Vega.
      Oct 2010
      Sacramento, CA
      You can reverse the way your switch works with a relay. Google car alarm relay schematics.
      Rick - 1969 Camaro - LS1 driven daily
      Denton Texas
      Ohhh thats a good one..
      Quote Originally Posted by ccmc View Post
      Feb 2011
      dallas, tx
      why not just a factory 69 neutral switch? thats what i used on my 67
      Atlanta, GA
      Like others said- add relay-
      But in mine I added a bypass.
      Sometimes - working on the car/on a hill- whatever- You don't have enough feet to push the clutch- brake and gas pedal-
      So I added bypass- that will latch the neutral safety switch-
      Turn on the ignition- push in the clutch-press the momentary switch- clutch safety switch is then bypassed till you- turn off the ignition OR push in the clutch again.
      Richard
