      Jonesboro, Arkansas
      Fuel Sending Unit for Early SBC
      Does anyone make a "in tank" fuel pump for a carbureted engine? I have mounted my Holley electric fuel pump everywhere, even with rubber between the pump and sheet metal and it's still really loud inside the car.
      Carl Wilson
      Apr 2012
      Woodstock, IL
      Not sure about low pressure,but we have done standard efi in tank pumps but need to run a bypass regulator to make it work.
      I'm sure you could use an early TBI pump from a 3rd gen and make it work..?
      SchwartzPerformance
      Beach Park IL
      We have done as Dale says several times. TBI pump in a Tanks tank with an aeromotive bypass regulator with return line back to the tank. Quiet and reliable.
      Donny
      Sep 2015
      Rockvale TN
      Jonesboro, Arkansas
      Thanks guys, One person I talked to said the LS type are too long and require them to be shimmed up at the top. They bottom out on the bottom of the thank. I have a Holley bypass regulator.
      Carl Wilson
