Results 21 to 40 of 61
Thread: DEI535 pwr window controller
03-26-2017 #21Registered User
- Mar 2017
- 13
I'm wanting to put one touch modules in my 64 Riviera, and the windows and regulators are large and heavy so I'm concerned about putting weak motors in. Are there different windings on these motors to make one model stronger than others? Has anyone here bolted the later reversing motors to old GM regulators? Just eyeballing them, it looks like they might bolt in but the clocking on the motor's body might be a problem.
I had also considered adding relays to increase available amps at the motors, directly after the one touch modules. Anyone know if that interferes with the modules function?
03-26-2017 #22Registered User
- Jul 2006
- El Paso, Texas
- 404
Most modules are current sensing so relays would probably gum that up. Best bet is to use a good power source and adequate wire that will handle the current. The previous poster on here, Harnessworx, seems to make good harnesses that would handle the loads. I looked at putting newer motors but you're right, it's tricky getting something to line up well. Believe it or not Ford motors seemed like they would fit better than the GM stuff I found. Most of the stock GM motors have holes clocked at 9-12-3 and it's hard to find any that line up. I went through the local junkyard and the older Fords seem have the proper type motors. You also have to factor in the teeth on the gears so they can mesh with the original regulator. I even bought some from Rockauto for $15-20 but again, lining everything up was the issue. I listed a part number earlier in this thread, DORMAN 742101, that is pretty universal. They're cheap enough at Rock that maybe you can get one to experiment. HTH.
Alex
03-29-2017 #23
