    Page 2 of 2 FirstFirst 1 2
    Results 21 to 35 of 35
    1. #21
      Drive Junky accessory drives
      These look great, a real step forward:
      https://www.pro-touring.com/threads/...50#post1224850
    2. #22
      Jun 2014
      Should have mine on order Monday! Zach is great to deal with can't wait to get it on the LT4!
    3. #23
      FL and Calif.
      LT-4 is a lot of engine for the price.
    4. #24
      Looks like the Holley pan is shipping.
    5. #25
      Jul 2011
      Nashville/ Tampa
      Did any of you guys ever try to use the 8l90? I know for the 6l80 people would use a G8 trans pan for clearance, but I'm wondering joe low an 8l90 pan would be in a Chevelle. Thinking of picking up a L86 / 8l90 combo now that they are fairly cheap to replace my l92/ t56.
    6. #26
      Denton Texas
      I just picked up a LT4 blower kit complete, blower, intercooler, pump, lines reservoir... I also got a L83 with the 6L80 with 18k miles..3500 total investment.. now to get it into my grand national
    7. #27
      Quote Originally Posted by qnitro View Post
      Holley now have LT specific engine side clamshells and poly inserts. They are designed to work with various Holley engine side LS swap mounts. In other words, any Holley LS swap kit will now work with the LT engines when used with these special clamshells. The Holley LT oil pan will work in a g-body.
    8. #28
      Denton Texas
      thanks.. Im gonna look into it..
    9. #29
      Mar 2013
      Andrew’s information about the Holley LT mounts is correct, but it won’t help you much in regards to your G-Body. The Hooker Blackheart G-Body LS swap engine mounting brackets are designed around the use of the original GM clamshell mounts that bolt to the frame of the car (AKA 2292 mounts), not the 4th-gen F-Body LS1 type clamshells (3364) that the new Holley LT engine clamshells are based on. The Holley 302-50 LT oil pan will be useful to you, but there’s not much else in the Hooker Blackheart system that will be at this point in time.
    10. #30
      Denton Texas
      Quote Originally Posted by Toddoky View Post
      I figure most my stuff will be one offs... I picked up my L86 Today, I have a TR6060 being built with a 2002 Fbody tail housing..I got the Blower kit in yesterday, Im going to do a Wegner LT4 Wet sump drive set up.. I think I can use the Holley Pan, and fab the frame brakcets..
    11. #31
      Woops. Sorry Todd!
    12. #32
      Mar 2013
      If you are prepared and willing to fabricate your own brackets, I would highly recommend using the Holley LT clamshell mounts Andrew mentioned on your engine. They are designed to compensate for the mounting bosses on LT block extending 3/8” further out from the block than the bosses on the LS block and will make it easier for you to get the crankshaft height as low as possible.
    13. #33
      Mar 2013
      No worries Andrew, it’s hard to keep all the details straight with all these different parts.
    14. #34
      Denton Texas
      I just bought a near new LT1 and bought a LT4 blower.. talked to Casey over at Wagner, gonna do his kit on the accessory drive, dirty dingo motor brackets..and figure out a mount for my TR6060.. haven't decided what to do for harness and comp..the pan I'm going to use like Andrew said using the Holley pan
    15. #35
      Apr 2012
      Woodstock, IL
      Nice. The LT1/4 heads are different so you'll need an adapter plate. There are a few companies that sell swap kits, I got most of my parts from https://lsa-conversion-store.myshopify.com/ - called them and got the stuff required for the same swap. Make sure Casey knows it's an LT1 with plates so you can get the correct length belt, as that will change slightly.
      -Dale
      SchwartzPerformance
