    Results 1 to 2 of 2
      Dec 2016
      4L60E Crossmember mounting location from centerline
      I'm looking for a dimension of a 4L60E. I need the vertical distance from the centerline to the crossmember mount. I'm trying to determine if my planned crossmember will work.
      Anyone have one out so you can get a measurement?
      Feb 2016
      Lawrenceville, IL
      If you haven't already figured this measurement out. I had a newer unit with the removable bellhousing here and measured 2.5" from the trans mount surface to the centerline of the output shaft.
      visit us on the web at www.bowlertransmissions.com
